Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-07-2007, 09:00 PM
racer1973 racer1973 is offline
Garage is empty, add now
racer1973 is starting off with a positive reputation.
Red face 98 ZX2 just quits running?
My wife has a 98 ZX2 with the zetec dohc. The engine light is on, the service station says the code calls out misfire on all cylinders? He says it probably starts out as one and then progresses to all. We have put new wires, plugs, coil packs. anyone else have this problem?
  #2 (permalink)
Old 12-10-2007, 06:14 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
Does it actually misfire? You can get a misfire code if the engine crankshaft sensor detects a change in rpm, which it could detect if it was not working properly.
Does the ECM have more than the 03xx codes? Do you have a leaky intake manifold?
Just a few thoughts.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
Tags
98, cylinders, ecm, engine, ford, injector, misfire, quits, ranger, zx2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
