Ignition Coil Specs for 97 F150 - Ford Truck Enthusiasts Forums
Old 03-21-2002, 02:49 PM
p_white p_white is offline
p_white is starting off with a positive reputation.
I recently researched specs for the ignition coils for a 97 F150 4.6l and found that in the Autozone manual they give two test criteria for resistance. The primary test taken from the three prongs where the wire connects has a range of .3-.7 ohms. The secondary test which is taken at the point where the spark plug wire connects has a range of 11.11-16.6 ohms. I checked a new coil while at Autozone and got readings of .8 ohms on the primary and 11.2 ohms at the secondary. The coils on my truck have readings of .9 ohms and 14.4 ohms respectively. I do not have a Ford manual to confirm the specs and was hoping one of you had one. My truck was missing badly so I replaced the wires and she ran good for a day or two then started missing again. Got a misfire code on # 4 so I replaced the plug(only 25k miles on it) and shes running good again. I have read where bad coils might make the wires and/or the plugs go bad.
Just looking for other opinions.
Old 03-21-2002, 04:01 PM
Yellardawg Yellardawg is offline
Yellardawg is starting off with a positive reputation.
If you continue to have problems in #4, go ahead and check compression in it.
YD
Old 03-21-2002, 04:21 PM
Post Ignition Coil Specs for 97 F150
I read where you had valve problems so I checked the compression and no problems yet. The plug looked perfect, the gap was still right on. Normally with a burn't valve you will get a puff of that ugly blue smoke right when you crank her over.
Old 03-21-2002, 06:28 PM
cigar4me39 cigar4me39 is offline
cigar4me39 is starting off with a positive reputation.
1995 5.0 No start SuperHighOutput Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 11-23-2014 09:43 PM
Slightly low resistance on ignition coil outdoorfan 1987 - 1996 F150 & Larger F-Series Trucks 7 09-16-2011 12:50 AM
ignition coil testing Clint1973 Bronco II 2 12-20-2010 10:45 AM
Engine Hesitates or Stumbles During Acceleration PersiusOne 1997 - 2003 F150 4 11-24-2008 07:19 PM
2000 4.2 coil pack check WVF150VIANC 3.8 & 4.2L V6 21 07-29-2004 08:11 AM
Tags
97, coil, f150, ingition, recomendations, resistance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
