Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-07-2007, 07:42 PM
calypsocowboy73 is starting off with a positive reputation.
Question Thermostat wont open, help!
Hey all, brand new to the forum, I have a Ford F-150 4x4 shortbed with a 302 in it. I have recently tried putting a new thermostat in, and it wont open up at 180f. I tested both the thermostats I have, and they tested fine. But when I put it in the truck it wont open up, all the coolant in the radiator and hoses stays cold and the block gets hot, and I have had the block up over 180f. Then when I take it back out and let it free flow, it works fine, accept obviously I don't have any heat and I cant get it up to operating temp. Everything flows fine , heater works fine but I cant put the stat in. Someone told me that it could be some sort of vapor lock , like air getting in somewhere and making a pocket behind the stat somewhere and not letting the stat open. Anyone have any insight on this, Im at a dead end. Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-08-2007, 12:22 AM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
It does sound like vapor lock. Drive her up on ramps and let it idle with the cap off (heater on). Watch for air bubbles and add coolant as needed until it stablizes.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #3 (permalink)
Old 12-08-2007, 07:14 AM
stuart1 is gaining momentum as a positive member of FTE.
Do you have it installed correctly?
If so you can drill a small hole in it to let air escape and properly fill the system.
I have also heard of placing an aspirin under the element which disolves and does the same.
__________________
Wrench twister since 1957.
Journeyman since 1964.
Transmission builder since 1964.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
