Edge Programmer
Edge Programmer
Wanting to know how I can program my new Edge Evolution Programmer for optimal fuel economy and performance? I don't know how or what the perimeters are without messing the timing up or getting bad gas mileage. Would like the correct numbers to do this and any other helpful tips. I drive a 2004 F-150 XLT Screw 4X4. Currently have a 2 1/2" leveling kit installed, MAC performance air intake kit, running 285/70/R17 Bridgestone Revos. Also, having trouble figuring out the right calculations for that tire size in mm. Thanks for your help
Mike
Mike
to set for your tire size, you need to set it to 2610mm. if you want to set a custom tune, then it depends on which octane fuel you are using. level one and two are designed to run on 87 octane, and level 3 is designed for 91 or better. now, if you run higher octane than the 91, you can increase your timing by .5 degress for each octane higher than 91. of course, if you notice pinging or detonation, then you should bring it back until it disappears.
Originally Posted by Frank'n'Ford
17"=431.8mm
1.) Multiply width x ratio x .02
2.) Multiply rim x 25.4
3.) Add steps 1 & 2
4.) Multiply step 3 x 3.1416
the result is the circumference in mm
this is what needs to be entered into the edge unit for it to correctly calculate the actual speed.
Mike
Mike
a customized tunes for your specific vehicle.
jdhudall
1997 - 2003 F150
10-26-2009 09:12 PM
