How much would an f150 weigh - Ford Truck Enthusiasts Forums
Old 12-06-2007, 08:07 PM
Fordenthusiasts's Avatar
Fordenthusiasts Fordenthusiasts is offline
Fordenthusiasts is starting off with a positive reputation.
How much would a 92-96 f150 weigh empty with a 351w, overdrive tranny, long bed, 4x4, reg cab, and dual tanks. How do they compare in weight to an 84 f150 with basically the same set up?
Old 12-07-2007, 09:48 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
My truck weighs 4750 on the local dump scales, the regular cab version is probably 100-200lbs lighter.
Old 12-07-2007, 10:32 AM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Depends on if it's 4wd, which is about 200-300 lbs.
An 84 with the same drivetrain/wheelbase would be within 100-200lbs of eachother.
Old 12-07-2007, 09:20 PM
jnewkirk77's Avatar
jnewkirk77 jnewkirk77 is offline
jnewkirk77 is starting off with a positive reputation.
Consumer Guide's review of the '90-96 F-150s shows the '90 regular cab long bed 4x2 at about 3975 lbs if I remember right. I'd guess 4WD adds 200-300 lbs. I don't remember seeing what engine their model had, but I think the 351 is not much heavier than the 302 (maybe 50 lbs.?), nor is it much heavier than the 300 six.
If anything, I'd have to guess an '84 would weigh about the same, maybe even a bit heavier owing to more metal in some places than the '92-96 models. Just a guess on that, though.
Old 12-07-2007, 10:18 PM
nickh nickh is offline
nickh is starting off with a positive reputation.
my 88 4wheel is around 4200 with 1.5 tanks. But can you really trust the scrap metal recyclers
Old 12-08-2007, 09:29 AM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
My 92 F150, 4x4, 5.0, manual, regular cab, and short box weighed 4350 pounds with a full tank of gas.
Old 12-08-2007, 11:04 AM
Thanks for the replys. I was guessing at around 4000 to 4500 lbs. I can't remember exactly but I weighed a 1991 explorer on co-op scales and it was either 4000 or 4400, I can't remember, and didn't figure the f-150 would way to much more considering it doesn't have all the carpeting and extra seats and the extra weight of all the metal and glass that encloses everything.
Old 12-08-2007, 01:10 PM
jllang2 jllang2 is offline
jllang2 is starting off with a positive reputation.
Look inside the driver side door, there is a badge that will tell you
Old 12-08-2007, 01:30 PM
phoneman91's Avatar
Quote:
The VIN sticker near the strike plate in the door jam will give the GVW/Gross Vehicle Weight of the truck. Not the empty weight.
Old 12-08-2007, 04:14 PM
TheRoadVirus TheRoadVirus is offline
TheRoadVirus is starting off with a positive reputation.
So I take it my shortbox/reg cab/manual everything should way about 4,000lbs correct? Oh and it's a 2wd 302..
Old 12-09-2007, 10:52 AM
The GVWR (gross vehicle weight rating) is not what the vehicle weighs, it's the max capacity of the vehicle (full weight) under load. So that is the maximum weight that truck can be when loaded.
Old 12-09-2007, 10:55 AM
vman vman is offline
vman is starting off with a positive reputation.
Your desc. matches my truck perfectly.It weighed 4400 with me in it and not very much gas.
Old 12-09-2007, 08:30 PM
jnewkirk77's Avatar
Most of you guys will find yourselves better off than I am, GVWR-wise. My truck is rated at 4900 lbs.! So, once you add myself, my three-year-old son and 1-year-old daughter (they're almost ALWAYS with me!), I can haul about 700 lbs., which is !!!
Old 12-09-2007, 09:36 PM
builtfordtough13's Avatar
builtfordtough13 builtfordtough13 is offline
builtfordtough13 is gaining momentum as a positive member of FTE.
I would say that they are both really close in wait, I would say that the 92-96 would way more, but within 500 lbs.
Old 12-09-2007, 10:06 PM
builtfordtough13, why would you say that the 92-96 weigh more? Do they have something extra that would weigh more? Are they slightly longer or taller so there is more sheetmetal or what?
How Much Does Your Truck Weigh ?? Paratrooper84 6.7L Power Stroke Diesel 30 02-11-2017 11:39 AM
How much does the frame weigh? 86fordtruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 01-03-2012 09:55 AM
1987 f150 Weight rommersk 1987 - 1996 F150 & Larger F-Series Trucks 1 03-26-2011 08:08 PM
1978 f150 4x4 weight? redsuperduty 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-03-2009 07:01 PM
How much does a 460 weigh? daywalker Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 06-05-2001 02:09 PM
Tags
1986, 1995, 4500, 4wd, 4x4302, 92, 96, bed, cab, f150, ford, king, long, pounds, pull, short, specs, weigh, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
