new alternator and battery, still discharging?
About a month ago my battery started discharging. I had the battery checked and it was okay, replaced the alternator (with Auto Zone's lifetime warrantied one) and it started and ran ok, still showed low charge on the gauge. I had to use my jumper box to start it once, then it worked for awhile (still not charging much) but quit again a couple of days ago, so I bought a new battery last night (Auto Zone's mid range) and put it in today. Started into town with it and it showed to be discharging slightly again, so I came back home. Have driven it a couple of miles twice this afternoon, still runs just barely in the normal zone.
Is the alternator bad, or could it be something else, like maybe the voltage regulator? I've never had to deal with that before, so I'm not sure what its symptoms would be. Any ideas would be appreciated.
Thanx for the info. I took my truck into an automotive electrical specialist after trying everything and it turns out there was a broken wire somewhere in the headlight circuit that was somehow causing a short and not letting the battery charge, or at least that was what i was told... Something that i had neither the patience or the time to find. not a bad deal either, 60 bucks an hour and it only took the guy 2 hrs. to find and fix the problem.
Camper Special Gene
01-29-2015 07:50 PM
Burner
Electrical Systems/Wiring
09-04-2005 09:12 PM
