Faulty gasket?
Faulty gasket?
How good is the ford exhaust gasket that the turbo bolts down to? I have been getting a hissing sound that is not the EBPV and noticed some smoke coming from under the turbo on startup. Got a new gasket from ford but it looks lame. Just a flat pice of steel. Hany hints on how I am going to get the bolts loose. They are rusted in pretty good.
well it is a possibilty.. but i would say it is a little bit of exhaust leaking from around where the down pipe connects... and what are you talking about when you say the exhaust gasket that the turbo bolts down to??? like the uppipes where they connect to the turbo??? and as far as i know where the turbo bolts down there is just a o-ring in there...
on
on
No I wouldn't try any sealant. probably wouldn't work any way. There are two other options that could be considered. IH has some bellowed up-pipes that use a bellow for the expansion rather than the donut gasket. I still haven't nailed down a part number though for our trucks. The Superduties can use them but I don't have a part number for the OBS ones.
Also I have heard that there are some new aftermarket donut gaskets that are supposed to be much better. I thought I heard Bean's had them but I can't find them on their website. Worth checking into to though.
As for the bolts they are not easy!! my pipes and gaskets were bad enough I jsut removed the turbo and slid the collector right off. so the bolts could be removed off the truck. Going back on wasn't too bad but still tight!
Wow! @#$%^& 800.00 for the bellow kit from International. Looks like I am going to be fixing leaks once in a while. Hey TJ, How long has it been since you fixed yours? My truck has 110000 on it and it looks like the doughnut gaskets have been replaced at least once before.
on
