You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Main775) 358-6400
__________________________________________________ _____________
another one
Dear Jimmye
Thank you for your email and apologies that we have not got back to you sooner.
With regards to dealership, it is necessary to have one of our processors and be set up making biodiesel. We would then need to see how you are getting on with it and assess your suitability to become a dealer.
To purchase a FuelPod, we would need to have a full delivery address so that we can make you a quotation that includes the shipping cost. If you would like me to make you a quotation or if you have any further questions, please do not hesitate to contact us.
I have also attached a document about the chemicals required. You may like to contact your local chemical supply and check that they can supply in smaller quantities. One batch needs approximately 10 litres of methanol and you may like to see if you can get hold of methylate solution, if not then caustic soda. We are currently looking into the cost of shipping for you, if in the meantine you have any further questions, please do not hesitate to contact us. Kind Regards Laura Watson
I built one in a couple of 55 gal drums, total cost: <$100. Can churn out 120 gallons a day.
FuelPod2 seems a bit pricey for what you are getting. it has a nice all in one design but you still have to go through the titrations and all the normal stuff. I still think the BioPro is a better unit, all stainless steel, glass lined tubing.. and it is a all in one design. It also does esterfication before transesterfication (acid then base) and thus is no need for titrations... (assume 100% and thus every batch uses the same amount of chemicals). It is set for a two day process.. fill... hit start... the next day drain off glycerin and start the wash cycle. It uses a water wash so it takes longer than the FuelPod2 dry wash... but I have seen the lab results and the biodiesel exceeds all the ASTM requirements. They are coming out with a dry wash unit for the BioPro probably this year. I haven't found as much info on the fuelpod2. The BioPro is more expensive though... sadly I cannot afford either one... THUS
I will end up doing something similar to AndyFords and use some 55 gal drums. Has anyone been using the foolproof method of processing? (acid/base) I am wondering if I will have some real trouble using steel drums and sulfuric acid? I am wondering how 380 ml of sulfuric acid mixed in 50 gal of oil and 6 gal of methanol will effect a steel drum? Doesn't seem like much to me and since it gets consumed in the reaction I don't see how it should cause any additional problems.
__________________ 1989 F250 4X4 SuperCab 7.3L NA (for now) 5sp 4.10 LS 1984 F250 4X4 SuperCab 6.9L ATS 093 Turbo T19 3.54 1985 F350 Flatbed 6.9L NA T19 (down)
