IDM Location?? - Ford Truck Enthusiasts Forums
IDM Location??
Old 12-06-2007, 10:41 AM
lhud lhud is offline
lhud is gaining momentum as a positive member of FTE.lhud is gaining momentum as a positive member of FTE.
IDM Location??
I have a 2002, F-250, CC, 4x4, Lariat. I also have a GOLD Superchip in the PCM - came with the truck that way.
I ran an AE check recently and got the 1316 DTC.
Now my laptop with the AE on it is down.
So, where would I find the location of the Injector Drive Module?
From other threads, I gather that the HVC connectors under the valve covers can be responsible for the 1316 DTC. I plan to pull the covers this weekend.
This is an intermittent problem. When it happens I notice a slight roughness, the check engine light comes on, the roughness goes away and the light goes out.
This sometimes happens two or three times in a short time and it then may not happen for a day or more.
Thanks guys,
Old 12-06-2007, 10:50 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
pull the driver side iner fender well.you will see the IDM..but check the harnes for sure
Old 12-06-2007, 11:37 AM
Ron,
Are you talking about the PCM unit that is located on the driver's side adjacent to the parking brake?
Or is the IDM located in that same area?
Thanks,
Old 12-06-2007, 12:18 PM
Quote:
Originally Posted by lhud
Ron,
Thanks,
yes it is kind of by the PCM..the IDM you need to remove the infender (just above the front tire)on the driver side..
Another p1316 scottddove 1999 - 2003 7.3L Power Stroke Diesel 11 07-31-2015 02:02 PM
p 1670 code affecting p1316 idm? vegtoph 1999 to 2016 Super Duty 24 12-06-2014 12:11 PM
clearing IDM codes (tugly) cps 1999 - 2003 7.3L Power Stroke Diesel 6 08-12-2013 11:45 AM
P1316 & P1139 Codes superchief 1999 to 2016 Super Duty 0 02-05-2012 10:10 PM
powerstroke p1316 monsterballz 1999 - 2003 7.3L Power Stroke Diesel 7 03-17-2011 12:28 PM
Tags
1316, 2002, 73, 99, driver, dtc, f250, f350, ford, idm, injector, location, module, powerstroke, removal, superchips
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
