tachometer
tachometer
is it possible to put a 302 5speed manual engine and transmition with originaly no tachometer into a identical truck with a stock tachometer.where would the extra plug be on the body/harness and where to plug it in into the engine..or transmition???
learning in progress!!!
mahalo-thanx
mahalo-thanx
HOWEVER
It is important to get a cluster for your year truck. Some years overlap but just because the cluster LOOKS the same doesn't mean it will work correctly. The cluster electrics were modified over a number of years, so for the least headaches and best results, stick with one from your specific year.
Also, there is a tech article under articles/specs that details the swap.
miashley150
13
08-22-2013 11:34 AM
