Front Axle Swap
Front Axle Swap
How many of you if any have swapped out the 50 for something better?
I am really thinking of swapping a 60 out of a 02-04 350. At first I looked at the Dynatrac conversion then added in the price of gears and what not, it seems like I could get a whole axle for damn near the same price.
What say you
What say you
Good point on still having the unit bearings.
I guess my hangup is whether to buy the Dynatrac kit and run it till something breaks
or
Buy a complete Dynatrac front axle assembly with the gears I want and a locker installed
It would be a while before I am able to do either but I guess I will keep looking around. You guys know any other decent axle builders that offer a complete axle to my specs.
My next step is lights and a rear locker. My Bumper looks lonely with all the empty places for lights and a winch.
One step at a time.
or
One step at a time.
Yeah I think the complete front end will be the way to go.
I have 3.73's stock but think 4.10's would be the way to go with my 35's. I have done quite a bit of looking and found a bunch of custom makers but most of them are out of my price range right now. I am also going to start looking at some of the older 350's that came with 60's before they went to the unit hub and see if they will match up. I do want to retain my ABS because I drive quite a bit on the road as well.
I will keep making wishlists I guess.
It is not that I need the 60 I just am comparing prices between upgrading my axle and buying new.
By the time I install new gears, and dynatracs bearing kit with high steer the price is pretty close to ordering a new axle to my specs.
The main things I dont like about my 50 is the unit bearings. I havent burned one up yet but part of the reason I am looking into this to begin with is that the cost of replacing both bearing units up front is pretty big. I know I will burn them up eventually running my 35's
I might just keep everything as is and buy a bronco to off road. But where is the fun in that.....
I use it all the time since I moved down to Nevada. Run any old mining trail I can find. Works great when I want to get out to the middle of nowhere to go shooting. I will keep upgrading my truck but eventually I will need something a tiny bit smaller and lighter to try my hand at some harder stuff.
LittleRadio
06-05-2014 08:46 AM
ltr450
05-01-2008 07:10 PM
