Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-05-2007, 09:05 PM
guss36 is starting off with a positive reputation.
no heat
i have searched and cant find the anser.i have a 1989 f-150 xlt.i have no heat out of none of the vents,no derfoster or nothin.not on the floor.when i first start it up everything is working,then a few miles down the road and nothin,the fan works but just no air comming out of the ducts.everything i read says it will defaut to defrost,but it wont do that either.any help would be appresated
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-06-2007, 07:41 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
You mean no warm air or is the air diverted to nowhere? Heres a diy instant heat solution that could be put on the floor return just for winter!!http://www.hackaday.com/2006/11/28/d...ic-car-heater/
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #3 (permalink)
Old 12-06-2007, 08:54 PM
67_forest is starting off with a positive reputation.
Couple of ?'s for you? When was the last time you flushed your radiator, and replaced your t-stat. This might help too, undo both of your heater core hoses and get a garden hose put it on the upper heater core spout and turn the water on gently. what this does is flushes the dubre out. Try that if that does not work let me know.
  #4 (permalink)
Old 12-07-2007, 10:20 PM
its not a problem with water flow.its airflow that i havent got.there is no air at all coming out of the vents.there must be a flapper in side the air box that dont open all the time.today it worked great.but the last 2 days i was pushing snow and i couldnt get no air at all out of none of the settings.
  #5 (permalink)
Old 12-07-2007, 11:18 PM
lsrx101 is gaining momentum as a positive member of FTE.
Quote:
It sounds like something is blocking the airflow through the heater\AC box. The usual culprit is many years of dust and dirt packed onto the AC evaporator or heater core. The intermittant nature of your problem seems to indicate that this is not the issue though. It's possible that a piece of paper or a rag somehow got into the plenum and randomly gets suckes up and blocks the air.
If the truck has AC (that works), the evaporator could be icing up even in low temps. Unplug the cycling switch on the accumulator (the can near the passenger firewall).
Pull the blower motor and look at the evaporator or heater core for ice/ debris blocking the airflow. There are no air door positions that would completely block the airflow. The air would be coming out of at least one duct.
One thing that "could" happen on an AC equipped vehicle (working or not) is that the outside air intake screen is plugged solid and the recirc door is set to "outside" air. Take a look at the outside air intake opening.
Another slight possibility is that the squirrel cage isn't spinning with the blower motor at times. I'm grasping at straws yes, but sometimes strange things happen. Yours is an uncommon problem.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #6 (permalink)
Old 12-08-2007, 03:05 PM
thanks.is it possible the evaperator was froze up and not letting air get to the heater core.i do no the i think its called filter dryer was froze up solid.if thats the case i would unpug the compresser.i havent had the defrosters on,and its been working fine out of the heater and when i put it on vent.
  #7 (permalink)
Old 12-08-2007, 05:58 PM
Filter Dryer=Accumulator. If the accumulator was iced up, so was the evaporator. There's your problem. Disconnect the cycling switch on the accumulator to disable the compressor. Actually, replace the cycling switch. That's probably what is causing it to ice up. They're about $10.
__________________
  #8 (permalink)
Old 12-08-2007, 10:03 PM
Quote:
thank you very much for the help.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
