Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 12-05-2007, 07:14 PM
bajaford bajaford is offline
Garage is empty, add now
bajaford is starting off with a positive reputation.
Smile 1990 F150 Shake from hell
I have a 1990 F-150 2wd V8 5.8 Liters with 101,000 miles on it so far...
the problem: I let the truck sit for several months in my backyard... now when I drive it, i think the front driver side tire shakes like theres no tomorrow. It's when I get up to about 35-40 around there.. It is not effected by bumps or applying breaks etc...just driving it.
What it has installed on it... -6 inch procomp lift with extended radius arms. Drop down pitman arm and a dual steering stabalizer. 37 inch baja t/a tires with steel wheels with twin ibeams. I just now replaced both ibeam pivot bushings as well as the wheel bearings. I know the alignment is a little out of wack...and I don't have any casters (slugs) installed for the lift..so the camber is off also. But it JUST started doing it all of the sudden when I started driving it again. It almost feels like my driver side tire has play in it when you try to shake it...but just barely. (when i shake it and look at it, it looks like the whole hub shakes with it (diskbrake) and all but nothing else? The tie rod in the front moves along with it...but i think thats normal? The passenger side has no play..but the inside of the tire is worn. I was just driving it after 7 months of sitting and after about 5 miles...it started. Upper an lower balljoints maybe? Do you think sitting so long might have warped my tires from the 115 degree summer? Tires have never been balanced.. It just seems weird to me that it would start shaking and my whole bed starts shaking in response to the front driver side tire. I have pics on cardomain.com
heres the link: http://www.cardomain.com/ride/2926000
any help would DEFFINETELY be appreciated (POST ANYTHING weither it sounds stupid or not...cause i'm out of ideas.)
-Preston
  #2 (permalink)
Old 12-05-2007, 07:29 PM
red58's Avatar
red58 red58 is offline
red58 is starting off with a positive reputation.
first thing if you have wear on the inside of the tyre you are in need of a whl align,secondly have a good look over ya front end,get someone to shake the wheels top to bottom and side to side on each wheel while you look at the suspension\steering,and check for any play and thirdly yes the tyres can flat spot if they have been sitting for long periods with the weight of the truck on them,they can come good but it takes a little while on the road
Tags
1990, f150, front, shake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
