Front Brake Diagram - 2005 F350 SD - HELP - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-05-2007, 06:09 PM
travis1880 travis1880 is offline
travis1880 is starting off with a positive reputation.
Does anyone have a brake diagram for replacing the front disc brakes on a 2005 F350 SD? I am replacing the brakes have done tons of cars/trucks, Chilton is not correct and just want to get this one right.....because its mine.
Thanks for your help
Old 12-05-2007, 08:21 PM
mobilefleet mobilefleet is offline
mobilefleet is starting off with a positive reputation.
if you have done brakes before you don't need a diagram, disc brakes are easy. If you don't feel confident then don't try it, expensive truck to mess up.
Mark
www.mobilefleetservices.net
Old 12-09-2007, 09:24 PM
I've changed hundreds of breaks in my life, thats how I payed for college. The reason I needed a diagram is to see if there is a wear indicator on this truck. The kit I purchased didn't include the indicators. This is my wifes truck and I like to have all the indicators working........
Old 12-09-2007, 09:25 PM
I've changed hundreds of brakes in my life, thats how I payed for college. The reason I needed a diagram is to see if there is a wear indicator on this truck. The kit I purchased didn't include the indicators. This is my wifes truck and I like to have all the indicators working........
Old 12-10-2007, 06:37 AM
go to your local dealer parts counter and ask to see a set of pads for your truck, then you can see what it should be looking like stock
Old 12-10-2007, 10:11 AM
VegasFX4 VegasFX4 is offline
VegasFX4 is starting off with a positive reputation.
There is no wear indicator on Super Duty brake pads. The brakes usually last for quite a while, depending on driving habits and conditions. Just be sure to inspect them regularly.
Old 12-10-2007, 10:19 AM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
I've never seen wear indicators on the brake pads on any of my SDs.
2005 - Ford F350SD 6.0 Turbo Diesel - Fuse Box Diagram ken2028 6.0L Power Stroke Diesel 2 12-29-2015 03:09 PM
Trailer Brake Controller in an SD lakewood 1999 to 2016 Super Duty 19 11-14-2012 09:41 AM
Brake Warning Light - E-350 2005 6.0 PSD gearloose1 6.0L Power Stroke Diesel 13 04-05-2010 05:46 PM
2005 Vacuum Hose Diagram GRUSSON 1999 to 2016 Super Duty 0 05-16-2008 02:36 PM
Brake controller wiring diagram for 2004 F350 HJV11 1999 to 2016 Super Duty 2 09-14-2004 05:46 AM
Tags
08, 1999, 2001, 2003, 2005, brake, brakes, diagram, diagram2005, disc, duty, f150, f250, f350, ford, front, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
