Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-05-2007, 04:06 PM
Dave58 is starting off with a positive reputation.
Y-Block reborn in '58 F-100
My '58 F-100 has been a very large yard ornament for the better part of 4 years now but the end is in sight. I recently bought a 292 longblock from S & S Engines in Spokane, Washington and put it into the truck. Last weekend I started the rebuilt engine for the first time and things went well. The only little problems were a little oil drip apparently from the oil pump to engine gasket and the clutch needs adjusted.
S & S built this Y-Block with a 264 degree cam and 95# valve springs. They 3-angle cut the valves and the intakes are the large 1.95s (I think that is the right number.) I put on a Blue Thunder intake manifold, Edelbrock 500 cfm carb and Mummert ram horn exhaust manifolds, as well as a clutch kit, a new radiator and alternator swap. I kept the three-on-the-tree for now but plan on swapping to an AOD later.
So, the body looks rough but everything from the firewall forward is new. I'm probably going to get the Y-Block emblem found on the T-Bird and slap those on the front fender as a point of pride. Other planned upgrades will be power steering, power front disc brakes and A/C.
Thanks to all of you who enjoy Y-Blocks for all your information.
Dave
__________________
His - 1958 F100 & 1987 Crown Vic
Hers - 2001 Escape
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-16-2007, 08:08 PM
pcmenten is starting off with a positive reputation.
I'll be very curious to know how that turns out. I recently bought a 'rebuild' 292. It had high ratio rockers on one head and low ratio rockers on the other head. I found several other assembly errors as I took it apart.
Needless to say I'll be doing my own y-block assembly. I don't really fault the engine rebuilder of my engine for the quality of the work, I just think y-blocks need an experienced y-block mechanic for the assembly work.
__________________
Best regards,
Paul Menten
  #3 (permalink)
Old 12-17-2007, 10:37 AM
Paul,
Here is a link to a webpage describing the engine I purchased.
http://www.rebuilt-auto-engines.com/...08107143336.6b
The initial start up was uneventful except for my rookie distributor mistakes. I still need to adjust the new clutch kit and hydralic clutch pedal so the truck hasn't been driven yet.
So far I'd give S&S engines a big thumbs up. All of our communications, both telephone and e-mail went very well. They sure seemed to understand the subtleties of the Y-Block.
Dave
__________________
Hers - 2001 Escape
  #4 (permalink)
Old 12-17-2007, 01:00 PM
HT32BSX115's Avatar
HT32BSX115 is starting off with a positive reputation.
Hey, How are you liking those Rams Horns?
I have a set from John Mummert and I even had them ceramic coated (flat black) They do look pretty
nice.
I didn't do the Blue Thunder but I did get a 4bbl manifold and I've got a Holley 4160 ready to go on it.
I'm also going to use a Pertronix distributor in it.
I had mine rebuilt by a local machine shop by a gray haired old guy. He seemed pretty knowledgeable about the Y. I also had him balance the rotating mass and he ported the intake ports.
Cheers,
Rick
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
  #5 (permalink)
Old 12-17-2007, 02:18 PM
Rick,
I like the Rams Horns alot. The single collector might not be the greatest for maximizing flow through the engine but they solve so many other problems. Besides, if I wanted HP per cubic inch I'd have gone to a different motor. The local muffler shop routed the pipe from the collector down the block like a blockhugger. This elimintated interference with the steering gear and keeps the pipes above the tranny crossmember. I coated my Rams Horms with the Duplicolor 1100 degree aluminum paint.
Like I said, I haven't driven it yet dur to clutch adjustment, but it sounds great in the garage.
Dave
__________________
Hers - 2001 Escape
  #6 (permalink)
Old 01-02-2008, 03:21 PM
My rebuilt Y-block had a little oil dripping from the oil pump area. I thought I put the new one on just like the old one, even used all the bolts in the sandwich bag from the old motor disassembly. But this pesky drip wouldn't go away so I looked closer and found a third oil pump mounting bolt hole in the lower web of the block. So I put a new bolt down into the oil pump from above and the drip is gone!
The previous onwer must have gotten luck and mounted the old pump with just two bolts. Ah, the continuing joy of the Y-Block.
I now have small coolant drips landing on the driveway on each side of the motor under the engine/bell housing joint. Anybody have any ideas? Could it be coming from the intake manifold?
Dave
__________________
Hers - 2001 Escape
  #7 (permalink)
Old 01-02-2008, 07:40 PM
The intake is a good place to start. In particular, there's a hole on the back of the driver's side cylinder head that needs a bolt, and that bolt needs to have thread sealer in it. The bolt is used to hold a spark plug wire loom in stock engines. The stock bolt is rather short.
__________________
Best regards,
Paul Menten
  #8 (permalink)
Old 01-02-2008, 07:56 PM
matt2491's Avatar
matt2491 is new and has a neutral reputation at this point.
Make sure that everything is sealed up with gasket seal stuff. One time coolant started leaking between the intake manifold and the thermostat housing. Took it apart, resealed it all around, and it was perfect after.
Sometimes it's the little things when it comes to drips and leaks.
  #9 (permalink)
Old 01-06-2008, 01:45 PM
Well, the water pump failed right after my most recent post. That doesn't really explain how the water got all the way back to the bell housing. When the new water pump is installed I'll check the intake manifold. The bolt hole in the rear driver side was fitted with a plug by my engine rebuilder.
Next issue; I ordered a water pump based upon the year of my truck - 1958, not the year of the block - 1960. It turns out the bolt pattern for the 1958 was much smaller than that for the 1960. Does anybody have the story behind the different sizes? Is my timing cover from something else, like an HD motor perhaps? I ask because my front engine mount and crossmember has the large single bolt not the smaller two-pad arragement.
__________________
Hers - 2001 Escape
  #10 (permalink)
Old 01-07-2008, 04:03 AM
Quote:
Next issue; I ordered a water pump based upon the year of my truck - 1958, not the year of the block - 1960. It turns out the bolt pattern for the 1958 was much smaller than that for the 1960. Does anybody have the story behind the different sizes? Is my timing cover from something else, like an HD motor perhaps? I ask because my front engine mount and crossmember has the large single bolt not the smaller two-pad arrangement.
Interesting. I'll have to dig through my stuff to see if there's a difference. Try posting this question on the y-blocks forever forum, in the technical section. I'll bet Ted would have an answer.
Y-blocks forever
BTW, it sounds like your motor mounts are for a F100 with the single large bolt. The two-pad arrangement is what I've seen on F250's.
__________________
Best regards,
Paul Menten
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
