Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 12-05-2007, 02:05 PM
JCrockett JCrockett is offline
Garage is empty, add now
JCrockett is starting off with a positive reputation.
Question Help-Rear ABS on 90F-350 W/O a computer
I have a 90 F-350 that I put a Cummins diesel into, it had a 5.8L EFI in it. My ABS light has been on and is bugging me. I replaced the sensor on the rear diff. I retained the ford speedo cable/sensor and adapted to the Dodge NP241 Transfer case. All the other connections look good at the master cylinder and the valves that are located on the frame rail.
I removed the computer from the truck as the remaining wire harness was not needed after the conversion. I was under the impression that the ABS system was seperate from the EFI computer. Does anyone know if this is not the case. If it needs the computer I will just pull the bulb and not worry about it. But from what I can tell from the wiring it should be a seperate system from the EFI computer.
If anyone has any ideas I would apprecaite it. I don't post on here that much, I did a search and did not find anything I haven't tried yet.
I also have the EFI computer for sale if anyone needs it, not sure what it is worth, but it is here in Alaska if anyone is interesed, I can ship it in a $8 USPS flat rate box.
Thanks
  #2 (permalink)
Old 12-05-2007, 03:26 PM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
I do not know of any connection between them.
Is your amber light flashing a code or is it on steady?
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 12-05-2007, 04:15 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Quote:
The wiring diagram I just looked at from my Mitchell Manual for your year indicates like all of the speed density F-trucks, the RABS system is self-contained and does not require the EEC to be there - in fact the EEC gets it's speed input from the RABS module, not the other way around.
What probably happened is while you unplugged connectors to remove various parts of the wiring harness, you've disconnected either the brake switch or the speed sensor. I'm not familiar enough with the earlier wiring but on my 93 F350 but right outside my firewall where the EEC is there are a couple of connectors that feed the speed sensor and brake pedal switch in and out to the various devices that need it - and disconnecting those connectors results (at least on my 93) RABS problems.
I don't have a diagram as to how the wiring is bundled for your year unfortunately, so this is merely a guess.
What I would do is plug all the EFI harness wiring back in, and drape it over the fender away from the engine and start the truck and see if the RABS is still unhappy. If not, then you know it's related to whatever parts of the harness you've disconnected. If it's still unhappy after this test, that indicates something else is wrong.
  #4 (permalink)
Old 12-05-2007, 08:12 PM
This light comes on when the truck is started, goes out for about 5-10 seconds then comes back on and stay on steady.
Thanks for the replys, I figured it was a stand alone system. Unfortunatly I do not have any of the wireing harness left, it went with the motor when I sold it. I do know that after my conversion was complete and I started and drove the truck the light was off and happy. Only after driving it for awhile after the conversion did it come back on and stay on. That is why I put in a new sensor, I also checked the fuse and it is in good, it fell out on me once and that kept the light on. I will check the connections again this weekend when I can work in they dayllight.
Thanks
  #5 (permalink)
Old 12-05-2007, 08:27 PM
subford's Avatar
Is the RED Brake light on at the same time.
__________________
subford@gmail.com
  #6 (permalink)
Old 12-05-2007, 09:39 PM
frederic's Avatar
If it functioned "fine" after the engine swap then it should still be fine, unless something wiggled loose or maybe something broke coincidentally.
If the wiring you removed was the problem, you would have gotten this problem *instantly*.
  #7 (permalink)
Old 12-06-2007, 10:05 AM
No the Red Brake light does not come on when then ABS light is on.
  #8 (permalink)
Old 12-06-2007, 01:42 PM
andym's Avatar
andym andym is online now
1989 Ford F-150
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Ford's rear ABS was so useless and ineffective that if it were me, I would just pull the bulb and forget about it. Then I would enjoy my Cummins diesel in my Ford.
Nice swap. I would love to do the same one day.
__________________
Andy
  #9 (permalink)
Old 12-06-2007, 02:22 PM
I am going to trouble shoot it one more time and if I can't get the system to work the bulb is coming out. The CTD is a joy to drive, gobs of power over the 5.8
Photos if your interested
http://www.turbodieselregistry.com/u...?userid=991498
  #10 (permalink)
Old 12-06-2007, 06:13 PM
BChance's Avatar
BChance BChance is offline
BChance is starting off with a positive reputation.
Did you run it in the air (tires off the ground), in gear, and hit the brakes?
  #11 (permalink)
Old 12-06-2007, 06:47 PM
Quote:
No, usally I keep the tires on the ground when I drive my truck. J/K
Will that reset the system or something? Never heard of doing that for the rear ABS.
  #12 (permalink)
Old 12-06-2007, 06:53 PM
BChance's Avatar
I've seen a few that have been run up on racks for testing, when the brakes are applied quickly, and with no load so that it stops the tires immediately, it takes out the rabs valve for some reason. They don't seem to like sudden stops. I don't know if they get stuck, or what happens, but they go bad instantly when they go..
  #13 (permalink)
Old 12-07-2007, 01:05 PM
Lazy K Lazy K is offline
Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.
Sounds like an outstanding conversation. For diagnosing RABS faults, pulling fault codes and listing for what each code means go to wwwdotraybestosdotcom/onlinetraining/abs-221.htm and I hope this can help you.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
