Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-05-2007, 01:55 PM
kpriddy kpriddy is offline
kpriddy is starting off with a positive reputation.
Wiring King Ranch Seats
I'm trying to replace the non-power cloth seats in my 1999 F-250 SD with a set of King Ranch seats. I have tried to locate a wiring diagram but nothing I've found is detailed enough to help. The passenger side has 2 wires so I figure that is power and ground but the driver seat has 5 or 6 wires I think. I can get the wire colors from the seats if that would help. If someone is able to help me I would really appreciate it.
  #2 (permalink)
Old 12-05-2007, 07:16 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all
What year are the electric seats?
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 12-06-2007, 08:47 AM
Honestly, I don't know. I bought them on ebay. He originally had the front and back plus the console but I only needed the fronts ( I have an XLT extended cab). He said he had someone who only wanted the backs so it worked out good. I think they were out of an Excursion. Is there somewhere I can look on the seat to find the year?
  #4 (permalink)
Old 12-06-2007, 11:19 AM
Franklin2's Avatar
List the color of the wires, main color first, and the stripe or dot color second, and maybe we can find a later diagram that matches.
__________________
Dave F
  #5 (permalink)
Old 12-06-2007, 12:12 PM
Thanks!! I'm at work right now but when I get home I will get as much info off of the seat as I can. I really appreciate your help.
  #6 (permalink)
Old 12-06-2007, 09:26 PM
I have the info. The seats appear to have been made in April 2005. There is a label on the harness that states "tested 4/5/05" and the part number 5C343600034APB3105.
The wires are as follows:
Driver seat
18 gauge? Brown with blue stripe (appears to be seat belt sensor)
14 gauge? Black
14 gauge? White with red stripe
14 gauge? Green
14 gauge? Red with black stripes
16 gauge? Blue with red stripe
Passenger side
14 gauge? Black with white stripe
14 gauge? Black
The ? are because I think that is the gauge wire. Any help would be appreciated.
  #7 (permalink)
Old 12-08-2007, 04:22 PM
Franklin2's Avatar
I tried to figure out your wires, but I can't seem to find what you need. I looked at a 2005 f150 diagram, and a 2003 superduty diagram. There are heated seats, memory seats, power seats, all with more wires than you seem to have. What I have listed below was common on both diagrams, and was the power feed from the fuse box. What I suggest is getting a small 10 amp battery charger, and hooking up to the wires. It seems that the black is always ground, so I think you are safe there. I would hook the + of the battery charger up to the other wires and see what happens. If something goes wrong, the circuit breaker in the charger should protect everything.
Driver's seat;
darkgreen=power
black=ground
Passenger seat;
red/white=power
black=ground
__________________
Dave F
  #8 (permalink)
Old 12-10-2007, 02:30 PM
Thanks for trying. I'll give it a shot.
  #9 (permalink)
Old 06-24-2009, 09:10 PM
Dread-Pirate Dread-Pirate is offline
Dread-Pirate is starting off with a positive reputation.
Howdy Franklin2,
I just read this thread and noticed that you made a comment about looking at a 2005 f150 diagram... I am now in the middle of installing King Ranch seats from a 2005 f150 in my 1997 f350. I would love it if you would list off the wiring for the drivers seat and the passengers seat. Please and Thank you.
  #10 (permalink)
Old 06-24-2009, 10:58 PM
Franklin2's Avatar
Quote:
Originally Posted by Dread-Pirate View Post
Howdy Franklin2,
How much of the seat wiring and modules do you have? Do you have just the seat and the motors, or do you have the modules and the seat switches and they are all plugged in.
__________________
Dave F
  #11 (permalink)
Old 06-25-2009, 12:03 AM
I think that I have everything except the harness that comes from the truck itself. I have the seats with the swithces attacthed to the side of the seats, the wires go from the swithces to a harness under the seat. If this does not answer your question, please define the switches, modules, and harness.
  #12 (permalink)
Old 06-25-2009, 10:51 AM
Franklin2's Avatar
Heated portion of the seat. Both these wires go to the heat control module.
Red/black goes to battery + hot all the time. It is a 30 amp circuit.
White/lightblue is another power wire that is hot only with the key in run. It's a 10 amp circuit.
Power portion of the seat. These wires feed the switches, and are battery + hot all the time.
Driver's side is a darkgreen wire from a 30 amp circuit.
Passenger side is a red/white wire and is another 30 amp circuit.
If you have the memory option, there is also a orange/lightgreen wire and a darkgreen that feeds the driver's seat module. The orange/lightgreen is a 5 amp, and hot all the time bat +. The darkgreen is shown to be the same darkgreen that feeds the switches. There may be a few extra wires that you will not need that go to the adjustable pedal assembly.
__________________
Dave F
  #13 (permalink)
Old 06-25-2009, 10:56 AM
Thank you very much, this will be a big help.
  #14 (permalink)
Old 06-27-2009, 03:49 PM
Andershoberg's Avatar
Andershoberg Andershoberg is offline
2000 Ford Excursion
Andershoberg is starting off with a positive reputation.
Seats
This is great info. I am just about to install my 2005 Harley Davidsson F-150 seats in my Excursion, so I have both frame and electrical issues... fixed the frame already, electrical to go...
The seat holds memory module, heat module, and pre-tension of seatbelt module (I am not sure about this last one, but there is something looking like a munition advice on the side of the seatbelt golder). I was just going to power up the dark green and black, and see if I can get the seat to adjust. Memory optional - heat later. I just disconnected the pre-tenisoner for safety.
Any advice?
Thanks in advance,
Anders
  #15 (permalink)
Old 06-28-2009, 02:00 PM
2000 Ford Excursion
Tried +12 volt to dark green, and gorund on black, and I have nothing. Any other pins in the global module that need power to enable the power seat?
Thanks,
Anders
Tags
97 , black , diagram , electric , f150 , heated , king , power , ranch , seat , seats , truck , white , wire , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
