04 F150
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2004 / Remote Start
12volts lt. green/purple (20A) + ignition harness
Starter red/lt. blue + ignition harness
Second Starter N/A
Ignition dk. blue/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/lt. green + ignition harness
Second Accessory N/A
Keysense black/pink + ignition harness
Power Lock pink/yellow - DKP or BCM, green plug, pin 9
Notes: The BCM (Body Control Module) is on the driver side rear cabin wall.
Power Unlock pink/lt. green - DKP or BCM, green plug, pin 1
Lock Motor pink/black 5wi DKP or BCM, blue plug, pin 2
Unlock Motor red/orange 5wi DKP or BCM, blue plug, pin 5
Parking Lights+ brown + switch or BCM, blue plug, pin 6
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light black/pink + DKP, gray plug, pin 13
Door Trigger black/yel (L), black/pink (R) - DKP, gray plug, pins 22, 23
Notes: The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is black/yellow in pin 4. The RF door trigger is black/pink in pin 5. The LR door trigger is black/lt. blue in pin 12. The RR door trigger is black/white in pin 13. Use all wires and diode isolate each.
Dome Supervision black/lt. blue + DKP, gray plug, pin 6
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT red/lt. green or red ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - parking brake switch
Horn Trigger dk. blue - switch or BCM, blue plug, pin 12
Memory Seat 1 brown/lt. green - memory seat switch on seat
Memory Seat 2 black/orange - memory seat switch on seat
Memory Seat 3 N/A -
Immobilizer Bypass Module: Required: Yes Type: SecuriLock Part #: 556S, 556U, or 555U
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Trunk/Hatch Pin N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 3 N/A -
