Tire Load Range Question - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-05-2007, 06:48 AM
diver45's Avatar
diver45 diver45 is offline
diver45 is starting off with a positive reputation.
What's the difference between a tire with a Load Range "D" that will allow for a MAX Load weight of 3195lbs@50psi and a Load Range "E" with a MAX Load weight of 3195lbs@65psi? I've read that D has 8ply & E has 10ply. How different is that, besides the obvious? Trying to decide on the BFG AT T/A K/O LT305/65R/17E and the LT315/70R/17D tires. This is an awesome sight.
Jerry
Old 12-05-2007, 06:53 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The 10 ply or Load Range E tires can take a heavier load. You can inflate a 10 ply tire to 80 PSI. It gives you a little more of a safety margin. About the last thing you want when you're towing is a tire failure.
A lot of guys that don't tow will use Load Range D tires. You'll get a little smoother ride out of those, everything else being equal.
Old 12-05-2007, 07:01 AM
diver45's Avatar
Since they are both rated for a MAX Load of 3195 lbs, does that mean there is a difference in their towing capabilities?
Old 12-05-2007, 07:04 AM
redford's Avatar
The D tire will give you a little more squirm at the max load rating, due to the lower pressure and "softer" sidewalls.
Old 12-05-2007, 07:41 AM
Pocono Super Duty Pocono Super Duty is offline
Pocono Super Duty is starting off with a positive reputation.
My BF Goodrich Rugged Trail Load Range "E" 10 ply are rated at 3415lbs. I needed that to support my 3000lbs Truck Camper safely.
Old 12-05-2007, 10:25 AM
sandman3510's Avatar
sandman3510 sandman3510 is offline
sandman3510 is starting off with a positive reputation.
I don't mean to point out the obvious, but when calculating the load capacity of your tires don't forget to take into account the empty weight of the truck itself that the tires will be supporting.
Example: E rated tires can support 3415 lbs, times 2, that's 6830 lbs. Subtract the rear axle weight of your truck (not sure what that is, let's say it's 3000 lbs for simplicity). 6830-3000 = 3830 lbs you can add to the rear of your truck.
I think this makes sense, let me know if i'm all wet. Again not trying to be a smart butt, just wanted to point this out. .
Old 12-05-2007, 11:13 AM
Ace!'s Avatar
Ace! Ace! is offline
Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.
You're right sandman3510, but not all "E" or "D" for that matter hold exactly the same. So, not all "E"s will be 3415. BFG makes a lot at 3195 and Toyo makes at least one that's like 3800 of something.
As Redford pointed out there will be more sidewall flex, "squirm", with the D tires, but they'll hold up the same weight if rated the same. You'll just feel it a little more when cornering, braking, etc.
I just went from an "E" to a "D" and notice the sidewall flex quite a bit. The "E"s were STIFF. The "D"s provide a much better ride; although both are rated at 3195. I bought the "D"s knowing that though and it was part of the reason I went that route.
Old 12-05-2007, 02:05 PM
HorseyHauler HorseyHauler is offline
HorseyHauler is starting off with a positive reputation.
The "ply" identification number has no meaning anymore. It was used to indicate the number of belts or layers of materials. The new letter designation is an equivalent indicating for example an "E" rated tire is equivalent to an older tire with 10 plys or layers. The development of new materials means my OEM BF Goodrich tires probably have only four belts.
Check this link for much more information about tires:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=55&currentpage=38
Very good point Sandman. In addition, do not forget a fudge factor in case of the loss of a tire by catastrophic failure. Have friend who had three tires go in succession (blow-out) on a heavy loaded trailer. Of course person never checked them before hauling. Duallies share the load in case of tire failure and engineers considered in the tire specifications.
Old 12-05-2007, 02:18 PM
diver45's Avatar
Thanx for the many responses, as you can see, there seems to be many different interpretaions to what is meant by the load range index. I just wasn't getting it by reading the different tire sites.
Old 12-05-2007, 02:42 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
I went to Sam's Club recently asking about tires for my truck, and they told me they would not mount "D" rated tires on anything that originally came with "E" tires.
Considering that I'm looking at 285/75R16's and a lot of those have a higher load rating at D than E-rated 235/85R16's do, I don't really understand why that's such a big deal.
Old 12-05-2007, 05:08 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
Quote:
Unless it's an oversized Load Range E tire....they are 65 psi.
My 325/60R18 Silent Armor Pro Grades are Load Range E, 3525lbs max @ 65 psi.
Old 12-05-2007, 05:45 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
All things being equal, such as size and weight rating, an E-range tire will run cooler on the highway than a D-range, and it'll provide more sidewall stability.
The increased flexing of the sidewall in the D-range is the reason for the higher operating temperature.
For example, my brother-in-law once put D-range tires on an Isuzu box truck that had a GVWR of 11,500lbs. It wallowed (tail wagging) on the highway with a big load on it. Michelins.
Same style tire, E-range, made a HUGE difference in the stability of the truck. Even though the actual WEIGHT rating was almost the same.
They lasted a lot longer too ...
Which is why, for the most part, everyone here recommends E-range for the Superduty when it's used to the max of it's capabilities. It's just common sense.
Load Rated Tire Recommendations Chriso83 1999 to 2016 Super Duty 17 04-06-2014 09:09 AM
Ya another tire size question. Gage2502 1999 to 2016 Super Duty 13 03-15-2012 09:41 AM
Tire ?: Toyo MT 285/75r17 (~34s) on 17x8s rkik Excursion - King of SUVs 34 02-06-2012 10:32 PM
Tire Rating D vs E rating rmrichards949 Excursion - King of SUVs 10 10-17-2010 10:54 PM
Largest tire for stock 17" rim 06infl 1999 to 2016 Super Duty 8 10-13-2007 02:31 PM
Tags
2005, difference, f250, ford, index, limit, load, mean, prices, range, rating, road, tire, tires, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
