Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-04-2007, 04:14 PM
arch07 is starting off with a positive reputation.
Question Electrical problems -- 4.2L
My coworker has a '97 F-150, 2 WD, 4 speed w/ OD, that has 242000 miles on it. The truck ran perfectly until a couple of weeks ago. The first problem that showed up was the heater fan would continue to run after the truck was turned off and the key removed from the ignition. Then we tried the turn signals and the wipers and they would also operate after the key was removed. Then the truck started shutting off while driving. Have noticed that this usually will occur at low rpm's or idle, not while running down the highway. When it shuts off, it will not restart unless the key is turned to the OFF position. If you try to restart it (after it shut down by itself), by turning the key to START, it will turn over but won't fire. Turn the key to OFF and then to START and it will fire right up. Just 2 days ago the speedometer started acting up. It will fall to zero even at 30-40 mph, and then it will start to fluctuate like there is a contact problem.
Have replaced the key switch, but the problem still remains.
Any and all help will be appreciated.
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-04-2007, 04:20 PM
ford dr. is starting off with a positive reputation.
Check the GEM module for codes. If it has bunches of codes in it, remove the central junction box and gem and seperate them. If you see corrosion, replace both and reseal windshield.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
