Powerstand(Wheelie)
Easy, Cheap too
Put the tail gate down an set two pallets of red brick behind the axle, Put it in low range, Max the R's and dump the clutch. Hee-hee It'd be an instant dump truck.
Oh! you want to do repeatedly,
Do a Short box, Cut out the firewall, set motor about as far back as you can (If not in the bed). Install above mentioned 1500hp motor, A Lenco Transmission and a Strange Engineering Rear end,then go talk to John Force for Tire recomendations.
Oh Yeah! Good long travel shocks up front.
Do 350's come in short box?
Haha, ok, so pretty much the general sensus is that I need mid/rear mounted engine, 1500 hp, and some serious tires. I guess thats not too bad......Hahaha. Well supposedly hen my mother first bought the truck new from the factory she had Mickey Thompsons Radias put on it cause she liked te look of wide tires in the rear. Shefigured it would give her better traction. Well her friend who was a drag racer, got it to stand up. Or at least that is what she said. So do you think your truck could stand if everything was brand new and you had some m/ts? By the way my truck has a 400 with a manual.
Dang, well I dont know any fat chicks but I do know where to get some bricks.....
In all seriousness, from what you guys are saying, especially mwvdub, it would take some serious work do it. Like huge torque numbers, really stiff rear suspension, gears that wouldn't be drivable on the street, and lots of money. I still think there is a chance.....
Heres a picture of my truck with maybe an inch under the left tire. 460/c6 3000 converter, 3.70 gears, spool, slapper bars, 325/50-15 drag radials, 150 shot right off the line.
Oh yeah it ran a best of 11.41 at 116 1.55 60 ft on pump gas driven to the track. Soon to be faster!
