Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-03-2007, 10:19 PM
JCastellaw is starting off with a positive reputation.
gas tanks
I reciently had a 351w installed in a bronco that I have had for a while. I assumed that the engine builder drained the fuel tank but after about 5 tanks run through it, I am starting to wonder. The fuel filter was clogged up and when water comes out if the tail pipes, it blows **** on the ground. Should I go through the trouble of removing the tank or keep using high grade and some sea foam????
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-03-2007, 10:32 PM
four4x4fords is starting off with a positive reputation.
I would drain it. The hose is right in the middle of bottom of the front of the tank.
__________________
01' F-350 4X4 SB CC V-10 Driver
76' F-250 4X4 428 Cruiser
68' Bronco Crawler
05' Explorer Wife's Driver
58 Fairlane 500 In progress
53 CJ3B off brand orphan
Reno, Nevada
  #3 (permalink)
Old 12-03-2007, 10:39 PM
would that be enough???
  #4 (permalink)
Old 12-04-2007, 11:22 AM
I don't know how much debris is in your tank , so I can't answer how much is enough.
You have to start somewhere.
__________________
68' Bronco Crawler
Reno, Nevada
  #5 (permalink)
Old 12-04-2007, 11:25 AM
Thanks! Would the sending unit be rusted up???
  #6 (permalink)
Old 12-04-2007, 09:08 PM
I have no idea. If the sending unit works, leave it be.
__________________
68' Bronco Crawler
Reno, Nevada
  #7 (permalink)
Old 12-05-2007, 02:53 AM
mauicruza is starting off with a positive reputation.
what type of debri is your filter trapping? Did your vehicle sit for a long period of time? Alot of times sitting for a long time can accumulate all kinds of crap. If your getting alot of junk, removing and cleaning is the only way. I've found power washing the inside does a great job.
  #8 (permalink)
Old 12-07-2007, 11:27 PM
savage066 is starting off with a positive reputation.
If you have no cats and an exhaust system with flowmaster mufflers or the like, you will always get soot in your exhaust and water blowing out the tailpipes on fire over. The air is cold and the exhaust is hot, and therefore you get condensation in the system that either gets trapped in the bottom of your muffler or blown out the back.
As for the tank... I'd get two of those clear plastic filters with paper elements in them that let you see the gas and put one in front of the tank and one in front of the fuel pump at the engine block. Then let the filters work.
If you are worried about water in the system, use dry gas to take care of that.
Draining the tank can help, but many times its not going to completely solve the problem of debris in the fuel system, because all the debris will not drain out, and what doesn't sits on the bottom of the tank, and many times work its way to the sender the completely clogs the system when you refill the tank.
__________________
-Rich
________________________________________________
'79 F-150, 300ci/SROD
'79 F-100 Explorer, 302ci/C4 - R.I.P. (jealous boyfriend firebomb )
'86 F-150 4X4 300ci/TOD/NP208/D44/8.8 - R.I.P.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
