Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-03-2007, 10:06 PM
BigFord74 is starting off with a positive reputation.
Glass polishing...
I'm needing to get something to polish some bad water spot's outta my window's and it seem's polishing is the next thing to attempt.
So, what do you use? Brand/equipment?
__________________
'05 Excursion V10 4x4 Limited - Stock for now....
'77 Bronco Uncutt...
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-04-2007, 10:58 AM
Ticman is starting off with a positive reputation.
I have had good luck with Meguiars #2 Fine Cut Cleaner by hand and rotary on glass water spots. You can find it at lots of parts stores like NAPA, O'Reillys and such.
If you have a rotary machine you could try the Megs #4 Heavy Cut cleaner if the #2 doesn't seem to be working. The #4 might be very hard to break down by hand. That's why I meantioned the rotary.
Tic
  #3 (permalink)
Old 12-12-2007, 09:48 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
I use Mother's clear coat wheel polish on my glass. You don't need much abrasion, so flitz, or other thin polish should do.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #4 (permalink)
Old 01-11-2008, 08:27 AM
03redstx is starting off with a positive reputation.
Griots Garage Glass Polish with a PC is the best i've found.
  #5 (permalink)
Old 01-17-2008, 02:40 PM
BChance's Avatar
BChance is starting off with a positive reputation.
glass cleaner (I use sprayway, cheap at Sams Club, and it works.) and 0000 steel wool. Just make SURE it's 0000. Shines it right up, water spots vanish quickly and relatively easy.
  #6 (permalink)
Old 01-17-2008, 09:13 PM
ReAX's Avatar
Molon Labe
I used to wax my windshield too, but it killed my wipers prematurely. I use Piaa Wiper blades that take care of the windshield between polishings.
__________________
-MECP 06/27/08
  #7 (permalink)
Old 02-01-2008, 10:10 PM
ACarbone624's Avatar
ACarbone624 is starting off with a positive reputation.
So I could use wax on my windows. Would it have the same effect as Rain-X?
  #8 (permalink)
Old 03-29-2008, 06:15 PM
Wieckster is starting off with a positive reputation.
yes wax works kinda like rain-x but doesnt last as long rain-x
__________________
CHAD
2001 F250 4x4 Lariet Extended Cab,Kwik Filter,5" Exhaust Straight-piped,Auto Meter Gauges,285's,WW,CCV,BlueCPS,Remote Start/W
alarm,8.2 BOSS VXT-Plow,Cool Pipes,Bilstein shocks,203 t-stat,ext coolant filter,Heated W/ turn signal mirrors
  #9 (permalink)
Old 04-05-2008, 10:14 AM
megawatt00's Avatar
Jaymi-Lyn says be a......
megawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to behold
When I clean my glass, I use a microfiber cloth. You can buy a pack of them at wally world in the automotive department.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back MBRP
6637 w/ Custom Cold Air Intake
Guages Next
PAA#14
Rick,Will ,JD, What Are We gonna DoNow?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
