Replacing stock head bolts?
Originally Posted by BIG-FUJIMO
Has anyone ever replaced the head bolts with studs one by one? take one out put one in. Before you start having any head problems.
This would be the procedure I would contemplate using. Remove the OEM bolts one at a time in the reverse order they were torqued from Ford, install the ARP stud and torque to ARP specs. This would allow the ARP studs to stretch which, if I remeber from my last ARP experience, is required. This would also keep the head from possibly warping and the head gasket sealed. Then the final step would be to loosen and re-torque the ARP studs to their final recommended ARP value in the recommended Ford sequence.
Standing by for grief!
DSMMH
well my ford tech told me about this while he was redoing mine he knows of a couple of guys that have done it and he didn't see a big problem with it as long as you do it while you know the heads haven't been overheated. basically like preventative maintenance. he told me take one out and put the arp stud in and torque it down. The only reason why I ask is I have two other low milage 6.0s I mean it almost inevitable its going to happen eventually.
Because you would be unseating the head and then reseating it on a used gasket. I just don't think it is a good idea to do it that way. and it is not as common to have the head bolt problem unless you run a chip or pull alot of heavier weight.
Originally Posted by bfloyd4445
Why not just replace them all at once them touq them down? as long as the heads aren't moved the gasket should keep a seal. right?
DSMMH
No its just what my psd guruu told me he said they been doing it with no problems
DSMMH
Yes you can do head gaskets without removing the cab or the motor but you will have to remove all of you front end. way easier
Originally Posted by DSMMH
Did your guru do the job with the engine in the truck or out? From what I read most HG replacements are done by removing the cab on pickup trucks. My X makes it a little hard to just remove the cab. I was planning to remove the IC, radiator and fan to give me enough room to stand in front of the engine and do the job without removing the motor.
DSMMH
DSMMH
rustyruststang50
11-06-2014 07:25 PM
broncoman604
01-18-2008 10:04 PM
