You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Anyone have their rear window leak water? We had two days of rain here and driving at night it looked like the rear window(hatch) had water trails on it. I washed the window thinking it was on the outside, nope, they are on the inside. It doesn't appear that there is any adjustments that can be made with regards to how close the glass sits to the seal.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
I have had the exact same thing. I coated the seal with 303 and that seemed to fix it. I think I have seen the same trails down the windshield as well but I need to do more testing. I should mention it to my service writer on my next visit.
__________________
White Sand 08 Expy EL Limited 4x4 with everything but the power running boards & trip tunes.
Thanks. I am going to spend some time looking at it tonight. I will try the 303. The seal seams way less pliable than other weatherstripping on the truck.
__________________
I also had the same issue before I got rid of my Expy. I cleaned the seals really good and didn't see it happen again. I figured that I must have gotten some trash/dirt in it from opening and closing in some the the dust areas I was in.
__________________
'08 F250 KR 4X4 Diesel CC Dark Blue
'07 F-150 SuperCrew Lariat 4x4 Dark Stone
Mine does, I always take the nozzle off the hose to rinse it off after I wash it - if there is a leak you will find it doing this. Never leaks any other time though. Could not telll it until the next day when the sun hit the glass at the right angle
Have you made it through any amount of rain with out it leaking?
__________________
My 2004 Expedition rear window leaked and my 2007 window leaked, what were the odds!
My dealer worked on this at least twice (one very long day). The factory has a fix which has worked so far.
The dealer finally installed new weather striping in the window frame. This new striping is almost twice as thick, you now have to be firm when you shut the window, and you can tell that there is more rubber to squish down when closing the window.
But so far so good, no leaks!
Sweet. Good news. I figured it was the weatherstripping. The one in there is stiff and when the glass is closed, hardly puts enough pressure on the glass.
My '05 does it too. From day one. I never got it fixed, I just wash the window.
Also, the little hose that connects to the rear window washer popped off once. Water dripping everywhere, fortunately no stains.
I had to pull down the headliner and reach in there to re-connect it. Took about 5 minutes. That's better than the 15-minute drive to the dealer and the 1-hour wait to get it fixed.
The owner's manual says to regularly clean all door and window seals and then wipe on silicone spray or dielectric grease (very sparingly). It works on my Vette very well to keep the seals clean, soft and sealing.
My rear seal is very "hard" as well. I don't see it sealing much as it looked like it leaked from the rain. The one I am really worried about is the windshield. Does anyone have any of the trail on their windshield? I am really hoping it was condensation...but I will be watching. Thanks for the replies in advance. You guys are great!!
__________________
It's raining now and knock on wood, I don't see any water leaking. I cleaned the seal with a damp microfiber towel rung out with warm water. I then pinched and rolled the base of the seal upward on the top horizontal section to make the seal protrude upward a bit. I then put 3 coats of 303 protectant on.
I will let you guys know Monday how it has held up, as its supposed to rain all weekend.
__________________
Windshields do not have gaskets. They are glued to the body sheet metal. If your windshield is leaking, it may be possible to pull back the trim strip hiding the seam and add some black polyurethane windshield sealant, if you can actually spot the leaking area. Alternatively, you will need to remov the whole windshield and have it cleaned and reglued.
