Battery Tutorial - Page 2 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Battery Tutorial
Old 05-27-2012, 09:45 PM
Tomm Tomm is offline
Tomm is starting off with a positive reputation.
On the money answer, PawPaw. Even though it looked to be in top shape, I took the + clamp apart on the battery and it may have been a 90 loss of conduction due to the corrosion under the top of the camp. Fired that brand new starter up with that brand new battery and the old pick-up is ready for another 115,000 miles.
Old 05-27-2012, 10:54 PM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Ok, good find, feedback & to hear the fix was an easy one & your on the road again!!!!
Old 08-26-2012, 03:27 AM
walpatal walpatal is offline
walpatal is starting off with a positive reputation.
great sticky
Old 02-10-2013, 11:33 AM
1989fordguy 1989fordguy is offline
1989fordguy is starting off with a positive reputation.
A friend of mine had a 1999 ford ranger broke down in my driveway. 4 cyl. They were havin trouble with it not starting from time to time. Lights come on, battery checks out ok, but it doesn't even attempt to crank. Cables are pretty corroded, can this b the problem? The relay in the power distribution box clicks every time I try to crank on it. I'm tired of lookin at this pos!
Old 02-10-2013, 12:19 PM
I agree that the corroded battery cables belong on your suspect list. Do an under load voltage drop test on both cables & their connections on Both ends with your multimeter, when your helper tries to crank the engine, as that test could narrow down your trouble shoot. The battery tutorial link has voltage drop testing instructions if your not familiar with how to do it.
Let us know how your trouble shoot goes.
Old 02-10-2013, 01:02 PM
I appreciate the advice, and will let y'all know how it turns out!
Old 12-16-2013, 12:55 AM
Voltage Drop Testing
How to use your DVM to perform voltage drop tests on suspect electrical connections. Voltage Drop Testing
Old 06-08-2014, 12:30 AM
clm2012 clm2012 is offline
clm2012 is starting off with a positive reputation.
Link not working
PawPaw - The link under you battery tutorial no longer works?
Old 06-08-2014, 01:03 AM
Thanks, we've had problems once in the past with this site loosing track of my link for some reason. Scroll down to post #5 & click on that link, it still works.
Old 07-05-2014, 03:23 PM
Quote:
OK, JeremyT put the fix on the link at 8:50 PM/7/4/14 & it works now. Thanks for the heads up. It happened once before & took a while to run down, just took a while to get Admin to look at it & Jeremy found & fixed the problem right on the spot.
Old 07-06-2014, 06:44 AM
From the tutorial, the bottom line on battery replacement.
"1.6. When buying a replacement starting battery, buy the heaviest and freshest battery compatible with the vehicle's charging system, with the largest Reserve Capacity (RC) and longest free replacement warranty that will physically fit in your vehicle, and sized with the Cold Cranking Amp (CCA) performance for the coldest climate the engine is started in. Normally replacing the OEM battery with the same type and size is the best choice. For deep cycle batteries, buy the freshest and heaviest battery with thickest plates and Amp Hour (AH) capacity that best suits the application, matches the charger, and has the lowest total cost of ownership. (Please see Section 7.)"
Old 01-11-2015, 01:31 PM
A state of charge chart with some specific gravity notes that might be helpful in deciding how your battery state of charge measures up with your hydrometer.
http://manins.net.au/motorhome/images/stateofcharge.png
  #28
Old 11-14-2016, 06:42 PM
97ranger xlt's Avatar
97ranger xlt 97ranger xlt is offline
97ranger xlt is starting off with a positive reputation.
LEAD-ACID BATTERY MANUFACTURERS AND BRAND NAMES LIST 2016
Should I use an 1985 year 12 volt battery charger to charge a new sear diehard? fightlivefree 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 01-26-2016 06:30 PM
2001 Navigator Alternator help. 68bluebeast 1997-2006 Expedition & Navigator 5 11-05-2015 03:49 PM
Importance Of Replacement Battery Type pawpaw Ranger & B-Series 1 03-02-2015 11:18 PM
How Long to Charge Both Batteries? Flame Out 1999 - 2003 7.3L Power Stroke Diesel 20 12-07-2013 10:30 AM
Trailer battery charging Eric Mowrer 1997-2006 Expedition & Navigator 9 03-09-2005 11:28 PM
Tags
anti, battery, cables, clicks, eye, ranger, theft, trucks, tutorial, unhooked
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
