84 alternator in 75 pickup
Old 12-03-2007, 02:35 AM
greythorn3's Avatar
greythorn3
greythorn3 is offline
OK heres is the story bear with me.. I have a 1975 crew cab short box ford f250 4x4 that had a 360 gas engine in it..
I removed the original engine, and installed a 1984 6.9 diesel engine in it with all the accessories..
I used the factory wiring in the 75 to hook to the 84 alternator.. but there are 2 push on wires that go to tha back of the alternator with caps on them, im not sure if i am hooking them to the right ones.. because when i run the truck with the regulator plugged in i have no charging.. and the regulator gets hot.. wondering (the reg is from the 75 also) what i could be doing wrong.. all these things worked before i did the engine swap and i have not altered much on the entire 75 ford harness..
Also does anyone kno0w hot to remove the amp meter from the wiring? i have a volt gauge im using instead hooked up..
Thanks
Ray
Old 12-03-2007, 02:54 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Take a close look at your alternator.
Some of the later alternators have a built in regulator (E73Z-10316-A - Motorcraft GR-784). It's a small black plastic device that bolts to the rear of the alternator.
Old 12-03-2007, 03:01 AM
greythorn3's Avatar
greythorn3
no it doesnt have that.. its got 2 plstic circles with posts and a battery connevtion./.. i got push on wires with colord caps.. ones orange and ones black....
Ray
Old 12-03-2007, 03:50 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
The 75 will have a "field F" hook up and a "stator S'' hook up. Do not use the stator wire. its for the old choke. all you need on the alternator is the field and the charge wire. You will also make the stock regulator hot and burn it up if the alternator is more than a 60 amp unit.
Old 12-03-2007, 03:55 AM
greythorn3's Avatar
greythorn3
i think its 60 amp.. mayeb i shoudl use the regulator for the 84 instead of the 75 one.. the 75 regulator has 3 long looking things on the back of it.. and if you dont ground it when its plugged in and runing it makes this click click click noise...
Ray
Old 12-03-2007, 02:14 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,654 Likes on 1,337 Posts
Are the terminals labeled on the 84 alternator? If so, what do they say? Also, what are the color wires going to the alternator in the 84 harness? We know what you have in the 75, but still unclear what exact alternator you have in the 84, so we need the info.
Old 12-03-2007, 02:26 PM
greythorn3's Avatar
greythorn3
i dotn have the 84 harness. the 84 diesel is in my 75 ford pickup with the 75 360 harness.. there are to plastic push on caps and a batt wire to the alternator.. one push on is black and the other is orange.. and there a 2 terminals on the back of the alternator marked fld and sta.. does orange to go fld or sta? on the 75 harness that is..
Ray
Old 12-03-2007, 10:40 PM
Franklin2's Avatar
Franklin2
The white/black goes to the stator terminal. If yours is black, just make sure the same black wire goes to the "s" on the regulator.
The orange wire goes to the field. You should have an orange wire on the "f" terminal of the regulator.
Old 12-04-2007, 12:00 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
This one ?
or this one
Old 12-04-2007, 12:03 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
How do you figure that ?
The Motorcraft V/R application number is the same for all non-integral VR alternators.
GR-540A
This includes 100 amp alts.. (not shown below)
http://www.rockauto.com/catalog/x,ca...,parttype,4884
Old 12-04-2007, 12:11 AM
bigblockford79's Avatar
bigblockford79
bigblockford79 is offline
Easiest Fix
If you are willing to spend a few bucks on a new alternator I would suggest buying a "self-exciting" model. These only have one wire and that goes directly to the positive side of the battery and you're done. I went to this on both of my trucks and couldn't be more pleased. Jegs has a great looking chrome one that is a 100 amp model for a little over $100. Otherwise your local auto parts supplier can set you up with one.
Old 12-04-2007, 04:05 AM
greythorn3's Avatar
greythorn3
thanks guys i hooked the orange push on connector wire to the field terminal and its WORKING!! left the other wire off the STA terminal since i dont need a choke.. 13.47 volts at idle! i didnt check the amps with my clamp on though.. also put the regulator in out of the 84 ford,,
thank you guys...
im just gonna tape the STA terminal wire back on the harness out of the way
Ray
Old 12-04-2007, 04:07 AM
greythorn3's Avatar
greythorn3
forgot to look to see if my amp meter gauge was working int he factory clushter.. i will check that tomarrow but i dont really care if it does.. i got a aftermarket volt meter.
Ray
Skip1970
02-07-2015 03:08 PM
77 Bronco
1966 - 1977 Early Broncos
01-16-2015 11:41 PM
g-man-75
08-09-2014 08:44 PM
mrblonde108
11-10-2011 09:25 PM
fast_st
09-05-2006 01:11 PM
Quick Reply: 84 alternator in 75 pickup
