4 Wheel Drive Making Weird Sound
We had a big snow storm today so I tried the 4 wheel drive, it seems to work but when I accelerate/decelerate at around 1800-2500 rpm I can hear/feel a weird kind of shudder/grinding noise coming from the front passenger side. At 60 mph with my foot on the gas it won't do it. Anybody have any idea what this could be? Thanks Justin
sounds like the IWE...... if enough damage has been done, then it will probably need replacing. if it did it randomly while in 2wd, then i would suspect a vacuum leak, or a faulty solenoid.... but if it does it only while in 4wd, then i would suspect the IWE, or even the hub if it has been chewed up enough.
My truck is a 07 with 6,000 m on it (so it should be under warranty) but it has a 8" Rize lift that was not installed at that dealership so I hope they don't try to say the lift caused the problem. I took it for a drive tonight and it doesn't do it in 2 wheel drive, just 4 high and 4 low. I guess I will take it in and see what the verdict is.
hoxiii
02-21-2004 07:54 PM
BobbyL
04-08-2003 07:56 PM
explorerxlt94
01-22-2002 10:18 PM
