12-03-2007, 12:51 PM
First make sure you get an accurate milage calculation, total volume of gas used in liters and total distance driven, the fuel level gauges cannot be relied upon for an accurate indication of fuel consumption. Also check that all emissions systems and sensors are connected and functioning properly, if the mechanics failed to reconnect a temp or O2 sensor, or damaged the connector for the same, or broke a vacuum line, milage will tank.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
