straight axle or IRS?
Personally I don't care for the "broken axle" look of trucks when set on the ground, but to each is own.
From a driveline point of view, each joint is meant to rotate in a certain angle and if you run it at severe angles then you set yourself up for some serious wear or vibration. Yes, they travel to extremes, but they are not meant for continued use in those extremes. Tire wear is another thing also.
Just some thoughts from an outsider.
Rokcrln
59
02-25-2017 05:50 PM
Oldcrowbarber
01-25-2016 06:07 PM
dclowrider
11-01-2013 01:41 PM
Drewsc
112
09-12-2013 09:03 PM
