6.0 Mileage ? - Page 2 - Ford Truck Enthusiasts Forums
6.0 Mileage ?
Old 12-03-2007, 09:47 PM
wildtide wildtide is offline
wildtide is starting off with a positive reputation.
I have drove it( F-250 ) in the stock setting and I will only get 12 to 13 MPG, On the open road with it set at performance level, with the cruise set on 70, I will average 17 to 18. I had the triple dog on this truck at stock height and I could get 23 MPG. I have a F-550 and I have ordered one for it. I only get 11 MPG in it at this time.
Old 12-04-2007, 04:26 PM
powerstroke1350's Avatar
powerstroke1350 powerstroke1350 is offline
powerstroke1350 is starting off with a positive reputation.
those triple dogs help with fuel mileage alot.
Old 12-04-2007, 04:48 PM
jfralph jfralph is offline
jfralph is starting off with a positive reputation.
Okay, I will bite, What is a "tripple dog"?
I believe a lot of the variances in fuel mileage are due to inconsistencies in production. I base this on having owned two of them, the first gave me upwards of 23 mpg on the highway @75. Its average was about 18 mpg empty. My new one, identical except for dual alternators, and one ton vs 3/4 ton, is happy if it sees 15 mpg @68 mph. It has a lot less power, yet ford says it is up to snuff in all catagories and has had lots of shop time to get it there. Both trucks are stock, driven by me exclusively, and I am getting older and more mellow as I age.
Old 12-04-2007, 04:56 PM
its a bully dog programmer
Old 12-04-2007, 05:48 PM
TowingMyBoat TowingMyBoat is offline
TowingMyBoat is starting off with a positive reputation.
Quote:
Originally Posted by skirk55
I use Diesel Kleen and try to keep my foot out of it and my best MPG empty was 14.7 I must be doing something wrong! Will a programmer or module help me get more MPG? I read that they do but what has people with them increased there MPG or any at all. Is what they tell me the truth? Or do they just deprogram HP to obtain the results? I just need the truth from owners!!!!
I have a 2007 SD Crew Cab with 5500 miles and purchased a Hypertech Power Programmer III and have been running with the #3 (greatest increase) for the last 3000 miles. The engine has more pep and power without a doubt but I haven't noticed a very big increase in mileage, the mileage for the last 3000 miles (14.22 mpg) is just about the same as the first 2000 miles (14.02 mpg). Even at the current price of Diesel of $3.60 this will take 40,000 miles to recoup the $400 the Hypertech Power Programmer III cost me. I have contacted Hypertech and they state that most users will see 1 or 2 mpg and are very happy with that. One last item to remember is that with the Hypertech, as well as other programmers, you will loose the lie-o-meter mpg as well as miles remaining to empty calculation (let me be correct you don't loose them they are just inaccurate such as my lie-o-meter reads 33 - 40 mpg almost all the time which I know is not correct).
Old 12-04-2007, 05:53 PM
ag-ford-4x4's Avatar
ag-ford-4x4 ag-ford-4x4 is offline
ag-ford-4x4 is gaining momentum as a positive member of FTE.
Quote:
I read people getting 20 MPG @ 75 MPH what is up with this?
Its called lying. I guess its possible its 'tuned'.
Old 12-04-2007, 06:12 PM
I'm reading that some guys are able to get 23 mpg at 75 mph. I'm no where even near that rating. In the May and June issue of DieselWorld they took a 2005 SD 6.0L and as a stock vehicle it got 17.4 mpg and they added components and got up to 24 mpg I would be happy with the 17.4 mpg the 24 mpg is a dream land for me.
I currently have a 2007 SD 6.0L Crew Cab and I have added an AFE Stage 2 Air Cleaner, a MagaFlow Muffler, and a HyperTech Power Programmer III (running at level 3). My current mpg average for the last 5,167 miles is 14.16 mpg, this is not from the lie-o-meter, this is from using the mileage at the start and at the end and tracking the total gallons from the 18 fillups. This includes towing my 4500 lb boat, a little around town, and freeway and highway driving. My tires inflated to 60 front and 70 back, drive w/ a light foot - minimize traffic light stops.
Does anybody have any advice for how I can increase my mpg?
Old 12-04-2007, 06:51 PM
skirk55's Avatar
skirk55 skirk55 is offline
skirk55 is gaining momentum as a positive member of FTE.
I guess with my 35" tires and 14.7 MPG I can't complain. I would like to purchase something that would boost it up by 2 or 3 miles/gal
Old 12-04-2007, 07:54 PM
blazerbud blazerbud is offline
blazerbud is starting off with a positive reputation.
No, people aren't lying. I have a 2004 superduty fx4 crew king ranch with 6.0 liter and torqshift. I also have an A.R.E. bed cover and 265/75/16 BFG's. I get 18.5 MPG all around up and down lots of hills as an average. When I get out on the interstate it can go up to 21 to 22,
I've always had good mileage. Even before I straight piped after the cat and had it tuned on a Dyna jet using a tripledog style remote.
Best torque numbers were at 690 ft lbs at the rear wheels.
Stock was around 350 at the rear wheels.
Old 12-05-2007, 08:26 AM
superchips and hypertech and quadzilla programmers are JUNK! please remove these novelty items at once. you need to dable in real programmers. such as: bully dog, edge, SCT!! these will get you better fuel mileage. take this advice and you will get the better mileage. also air intake and proper exhaust. dr. performance chips are good for fuel mileage, but dont use them for extra power. they will ruin your engine.
Old 12-05-2007, 10:17 PM
sethjamto's Avatar
sethjamto sethjamto is offline
sethjamto is starting off with a positive reputation.
I have an '03 F350 SRW 6 speed manual that is bone stock and I've gotten as high as 19.5mpg's on the highway with the cruise set at 74-75mph. I will usually get closer to 18.5-19 though. And this is all hand calculated...I don't have the fancy computer that lies to me!
I'm sure that it also helps that I run purely highway and its on the totally flat interstate of I-10 between Mobile, AL and Gulfport, MS. No hills and sea level....
Old 12-05-2007, 10:32 PM
MattyNJ's Avatar
MattyNJ MattyNJ is offline
MattyNJ is starting off with a positive reputation.
unreal...I get 10.4 round town, and 14 tops hywy.....Ive never seen close to 20mpg even when brand new of the lot bone stock.
  #28
Old 12-06-2007, 02:18 AM
hott-rodd hott-rodd is offline
hott-rodd is starting off with a positive reputation.
describe you truck when you state mileage.
A reg cab 2wd Sb SRW stock size tires and 3.73 gears should do much better
than crewcab lifted LB fx4 dually with oversized tires and 4.10 gears.
My CC LB SRW 3.73 get ~14-16 normal and has gone 19+ hwy
  #29
Old 12-06-2007, 06:25 AM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is gaining momentum as a positive member of FTE.
exactly!! There are so many variables that can make a huge difference. Where you drive (flat or hilly, hot vs. dammit cold, gears, tire size, type of tire (huge difference between the contenental highway tire and the Cooper SST), driving habits, modifications done on the truck, 2 wheel vs. 4 wheel drive. Not to mention the fact there are some out there that are OBVIOUSLY streching the true or just can do the math correctly. If it sounds to good to be true....it probably is. 23 MPG......maybe with the truck shut off. And if you look at where some of these outragously high MPG claims are coming from...... Think about it if you live where it gets cold, your truck will not get as good of fuel mileage. Due to warm up idle time and the fact that your engine will not run efficiently till its warmed up.
Some of your noses are growing gentlemen.
  #30
Old 12-06-2007, 06:31 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
2wd vs 4wd; lifted vs not; tire size; etc certainly make a noticeable difference.
To be believable, all numbers reported should be hand calculated. The electronic reading is just NOT that accurate.
A big factor that people do not report in their numbers is wind! I have gotten 19.5 two times and over 20 once. All three have been on the highway with a 15+ mile per hour wind behind me. 18.5 is a better highway number for me on the highway with no wind, no towing, 65 mph, etc.
Also, some pumps are just not set to stop at the same point. This can skew the results also. I always look at the mpg before and after a hand calculation to make sure a very high number is not followed up by a very low number. If so, the tank may not have been filled up consistantly.
When folks just can't get decent mileage, I wonder how big a part a bad (or poorly calibrated) sensor might play?
Does anyone know which sensors would play the biggest role in mpg performance? It may "pay out' to replace a sensor or two for 2-3 mpg??
Maybe this is just too much of a long shot with the fact that it could be injectors, ring and valve blow-by etc.
1999 F150 5.4 before and after bolt on upgrades jdhudall 1997 - 2003 F150 14 03-27-2012 04:40 PM
What mpg you get out bronco and list what you did to get good mpg Milwaukee1979F150 1978 - 1996 Big Bronco 29 09-30-2009 03:14 AM
Mileage skirk55 Delaware Chapter 14 09-27-2009 12:27 AM
Some thoughts on measuring MPG for a PSD... ernesteugene 1999 - 2003 7.3L Power Stroke Diesel 21 06-09-2008 08:42 PM
Larger Tire MPG? skirk55 1999 to 2016 Super Duty 5 04-20-2008 09:48 PM
Tags
60, 73, f350, ford, gibson, good, header, hypertech, max, milage, mileage, powerstrock, psd, speed, srw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
