Help With C6 Transmission!! - Ford Truck Enthusiasts Forums
Old 12-02-2007, 02:55 PM
F250GreaseMonkey F250GreaseMonkey is offline
F250GreaseMonkey is starting off with a positive reputation.
Hey guys im still pretty new to this forum but you guys seems like good knowledgeable people. Anyways i have 73 f-250 2wd with a 390 an a c6. My question is does anyone know were i can find a schematic or diagram of the valvebody in a c6 transmission. Problem is i had a friend of mine who said he knew what he was doing rebuild the c6 and put a shift kit in it while he was at it now i got it all installed with a tci 2000 stall converter and filled it all and hooked everything up and the trans wont engage any gear it wont do any anything at all i asked the guy he says the shift kit was very vague about what springs to replace in the valve body so hes not sure if he did the valve body right and he thinks thats the problem and he says we need a diagram of the valve body to figure it out now so if anyone out there knows were i can get a diagram of the valve body youd be doing me a huge favor thanks in advance
Old 12-02-2007, 06:21 PM
masterbeavis's Avatar
masterbeavis masterbeavis is offline
masterbeavis has a very good reputation on FTE.masterbeavis has a very good reputation on FTE.masterbeavis has a very good reputation on FTE.
First verify the torque converter is engaged to the flywheel (don't laugh, I have seen it before) Second, check your fluid level. If you are 2 QT low, nothing will go. Third, drop pan, check that the shift linkage is engaging the VB correctly. Fourth, use supplied directions to verify check ball and spring location. The springs are color coded, you might need to call the manufacturer for assistance.
I looked at my shift kit instructions, it seemed prettly clear on what is supposed to go where. I could not find my ATSG book.
Old 12-02-2007, 06:51 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Welcoem to FTE!
FTE has a Drivetrain forum where specific transmission questions can be asked. This forum is for the 73-79 truck overall
Maybe read these before checking in the drivetrain forum
http://www.technicalvideos.com/ident...smission.phtml
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 12-02-2007, 07:08 PM
well ive seen the shift kit instructios and they are vague and he says a couple of the springs the kit says to replace didnt quite fit right but he used them anyways....yea so anyways i cant find a diagram of the valve body i have the original factory service manual but it dont show the valve body just the rotating assemblies so who knows. Sorry i didnt know there was a forum for jsut drivetrain stuff i didnt see it ill repost there but thanks for yur input guys
Old 12-02-2007, 07:15 PM
I have some original Ford service technician books for the C-6 that I could scan if need be.
Old 12-02-2007, 07:50 PM
Old 12-02-2007, 10:04 PM
thank you much million these hopefully help i do not know much about transmissions at all im a motor guy lol so hopefully my guy cxan figure this out but its filled with the proper amount of fluid the torque converter is in all the way its all bolted up i dunno why it wont engage anything he says he thinks its the valve body. kinda wish id taken it to someone else lol
Old 12-02-2007, 11:50 PM
fasthauler's Avatar
fasthauler fasthauler is offline
fasthauler is gaining momentum as a positive member of FTE.
I don't know if this will be of any help, but your welcome to it.
Old 09-24-2008, 11:31 AM
caplette caplette is offline
caplette is starting off with a positive reputation.
I was looking at the valve body diagram anf I too put a shift kit in my C6 73 ford and it didnt respond like I thought it would, I may have done some thing wrong, on the picture does the ball have to be on top of the spring or the bottom? or the bottom. it didnt shift right and had serious shift lag lol. so I put everything back to the way it was and it still dont shift right.
Old 09-24-2008, 07:42 PM
Tedybear Tedybear is offline
Tedybear is gaining momentum as a positive member of FTE.
Just a side bar note:
It's very possible, and all to easy to over tighten the small bolts that hold the valve body to the housing. If they are not torqued in the exact manner/method as listed? The valve body can actually "distort" just enough to cause the spool valves to bind up a tad.
Just a heads up.
S-
Old 09-24-2008, 09:40 PM
jk080's Avatar
jk080 jk080 is online now
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
Quote:
Ball on top of the spring.
Old 01-02-2010, 03:56 PM
vintagemerc vintagemerc is offline
vintagemerc is starting off with a positive reputation.
C6 tranny
Hi.
C6 2-3 faster shift help.
I need a bit of assistence to find the place to Drill a .76-inch hole in the separator plate as outlined in a shift kit manual.
It would be appriciated.
Cheers.
kim.
Ireland
Diagram for C6 Transmission Jam Ras 1987 - 1996 F150 & Larger F-Series Trucks 7 02-02-2017 10:37 AM
HELP!!! with 4R100 in 2001 4x4 musthunt 1999 - 2003 7.3L Power Stroke Diesel 6 01-20-2014 04:11 PM
C6 transmission option - need opinions alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-15-2013 12:29 PM
E40D hard shift requiring an overhaul? rknight29 1994.5 - 1997 7.3L Power Stroke Diesel 64 11-03-2011 04:34 PM
C6 Shifting problem solved! 71LTD390 Clutch, Transmission, Differential, Axle & Transfer Case 14 01-22-2007 07:11 PM
Tags
1975, 1989, 89, breakdown, bronco, c6, diagram, f150, fluid, ford, kit, mounting, operation, rebuild, theory, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
