Low tire pressure because of cold weather? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-01-2007, 10:20 PM
the Goat the Goat is offline
the Goat is starting off with a positive reputation.
<meta name="GENERATOR" content="OpenOffice.org 2.3 (Unix)"> <style type="text/css"> <!-- @page { size: 8.5in 11in; margin: 0.79in } P { margin-bottom: 0.08in } --> </style> We just got our first winter day here (8 degrees Fahrenheit). When I drove the super duty the low tire pressure warning came on after ten miles. When I checked the tires' pressures all four were 12-15 psi low. Is that a normal amount of pressure to lose just due to cold weather? I find it hard to believe that all four tires have a slow leak or somebody lowered the pressure on all four wheels, etc. But I wouldn't expect the factory system to trigger due to normal weather conditions. Either way I just spent ten minuets freezing my back end off filling the tires to get the low pressure system to shut up.
Old 12-01-2007, 10:41 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
That depends...when was the last time you checked your tire pressure? Seems to me...that what you experienced...is normal, if you haven't check tire pressure in some time. Especially...since they were all about the same low pressure.
Keep an eye on them for the next few weeks...
biz
Old 12-01-2007, 10:44 PM
Hootbro's Avatar
Hootbro Hootbro is offline
Hootbro is starting off with a positive reputation.
Not unusual. For every 10 degree drop, you can expect 1-2 PSI drop. More if the tire is bigger like a truck tire.
The density of air expands and contract with the temperature. Aircraft tires use nitrogen for this and other reasons to maintain stable tire pressure.
My four cars at the house experienced this recently when our first winter temp drop hit us.
Hootbro
Old 12-02-2007, 09:11 AM
Quote:
Well I've actually never checked the pressure in my tires. The truck is two months old (900 miles). So it looks like the factory did a half-a$$ed job filling the tires. That combined with the cold weather dropped the pressure enought to trigger the low pressure sensors.
Old 12-02-2007, 10:31 AM
UP_There's Avatar
UP_There UP_There is offline
UP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud of
Shame on you! Gotta keep track of that stuff! Anytime I buy/test drive anything I make sure I check all the "vitals" tire pressure included.
Quote:
Old 12-02-2007, 10:37 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Very common. My wife's Murano has TPMS, on real cold days you sometimes get a low tire alert. Her tires run at 33 PSI, when you get down to 10F the tires can easily lose 9 PSI.
Old 12-02-2007, 10:59 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Yeah, this happens all the time, especially if the vehicle sits quite a bit. Doesn't matter if it's a truck, 4 wheeler, or a dirt bike. And I second what UP_There said, always check tire pressure, especially when buying a new or new to you rig! When I bought my 00 Yamaha YZ 426F dirt bike new in April of 00, I couldn't figure out for the life of me why the thing felt like it was riding on solid ice everywhere I went. After 3-4 rides I checked the tire pressure- 30 PSI in each tire, max is supposed to be 12! Plus, keeping your tires properly inflated will help extend the life of your tires, and with the price of a tire these days you can't afford to be wearing them out too quickly.
Old 12-02-2007, 11:18 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Lots of dealers do this. They run the tires low so test-drivers think it rides great.
Old 12-02-2007, 03:18 PM
Thanks for the input guys. When I bought the truck I went through the effort to put the pressure guage in the glove compartment but I didn't think to check the pressure. Now that I think about it, of corse I should have checked.
Treadwright... TBigLug 1999 to 2016 Super Duty 21 03-04-2014 01:10 PM
No voltage at pin 4 ICM plug. Timing advance not working need help! Posimoto 1987 - 1996 F150 & Larger F-Series Trucks 18 01-03-2012 07:13 PM
Hard to turn when the brake is appled kc0ti1002 1999 to 2016 Super Duty 16 09-21-2010 10:16 PM
2001 B3000 Cranks but won't start. Ugh... MazDoc Ranger & B-Series 12 03-30-2010 05:12 PM
Low voltage at trailer plugs scubadog 1999 to 2016 Super Duty 17 04-30-2009 12:17 PM
Tags
1999, cold, cool, due, f250, ford, leak, losing, low, p21560r17, pressure, psi, tire, tires, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
