Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-01-2007, 10:06 PM
Snowking's Avatar
More Booze Less Guilt
Snowking has a good reputation on FTE.Snowking has a good reputation on FTE.
one word Uh-oh
Ok I'll keep this short.
I got antifreeze coming out both exhaust manifolds on a 239, what could all be screwed?
tear down is set for tommorrow and I'm preparing for the worse.
heres a vid from today
http://youtube.com/watch?v=0xXk4aNTKRY
__________________
only the finest junk around
2000 Ford F150 Supercab
1947 Mercury 1/2ton
1949 Mercury M47
1951 Mercury M-6
1952 F-1
1957 F250
1964 Mercury M100
1967 & 69 F100
4 old Internationals/ Dodges (Hey, Nobody's perfect)
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-02-2007, 12:39 AM
mtflat is gaining momentum as a positive member of FTE.mtflat is gaining momentum as a positive member of FTE.
Either blown head gaskets (leaking from water jacket into the cylinder) Often blows combustion gasses into the radiator, making the coolant foamy.
or the head gaskets are installed wrong (usually flipped end for end - and the coolant holes don't line up right)
OR - worst case, a crack on both sides between cylinder and valve pocket
I have one with a crack in #6 cylinder to intake. With thermostats in place it'll empty the radiator pretty fast.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
