Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-01-2007, 12:49 PM
33 4X4 is starting off with a positive reputation.
transmission swap
I have a 33 ford pu with a 70 Bronco 3 speed manual 4x4 setup. Engine is a 302 and the transfer case is a Dana model 20. I want to go to a automatic and keep the 4x4 drive line. What automatic transmission is the best choice? A 4th gear or overdrive would be nice... An alternative is a 4 or 5 speed manual transmission....Thanks for helping....Jim...jwturbett@msn.com
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-01-2007, 04:13 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Automatic, AOD of the proper (later years, V8 models) vintage, with maybe a beef up and the proper linkage...a big deal on this trans. Note lower 1st and 2nd can be had.
http://www.transmissioncenter.net/AOD.htm
http://www.becontrols.com/products/aodcat.htm
http://ckperformance.com/ford_aod.html
http://www.tciauto.com/Products/Ford/ford_aod.asp
Or C4 if you want to pass on OD.
Manual would be Mazda or ZF models, although you need a juice clutch for both. T5 would be maybe but 1st is too high. Ford 4 speed OD would be like your 3 gear with OD, and floor shifter.
http://www.motivegear.com/tech_info/...nny_guide.html
http://www.moderndriveline.com/index.htm
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
