Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-01-2007, 12:44 PM
heymrdj is starting off with a positive reputation.
95EB Bronco Repairs (different things)
Hello yall, seeing that we got the shift thing taken care of, I want to continue making dad's bronco a daily driver again.
So first of all, need to repair the cruise control. It hasn't worked for years. This is what I know so far:
The on and off buttons on the column work. When i push coast, set accel, or decel you can hear a relay or something clicking in the dashboard on the driver side near the A pillar. When you hit the off button and try to push those buttons, i get no click. When i hit the on button, then hit one of those, i get that click. At no time however does cruise work, and the cruise light never comes on. A shadetree mechanic presumes a cluster switch which he said he isn't good enough to repair so he left it alone. Knowing that it's getting as far as a relay, what do you guys presume? What can I check next.
Next issue is temp guage. The Bronco is used to tow a bass rig to tournaments. On a run, years ago, to Okachobee (sp?) the temp guage went crazy on the way down, flipping rapidly back and forth between the two pegs. Then went normal. A few days later on the way back it did it again, then just fell to the left side (the C side peg) and just lays there. Has for all these years. Never gets off that peg, just lies there, limp like. We replaced the temp sensor but that did no good for it. That's where it was left. Any clue on that one?
Next is the driver's side window. We believe it is the regulator gear that is stripped causing us trouble going up and down. We purchased, from NAPA, a Window Regulator Gear, part 665-1502. It's a 52 tooth gear. It also comes with 3 plastic things, kinda like opaque white jelly drops. No clue what is in there. Can anyone show a guide on removing the door panel on the truck safely without breaking things. Fixing this will really help dad.
I think that's all for now. We get these fixed and we're ready for new tires and exhaust system.
EDIT: Also would like to state the Bronco did have it's TSB performed, on the cruise control switch known to burn. I believe it's mounted to the master cylinder. Any ways, it was done about a year ago.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-02-2007, 02:55 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
The dealer may very well have just left the cruise control disconnected for the tsb
which is what they did because they did not have enough of them when the tsb
went out, So check if the wire is disconnected right there at the MC or anywhere on
the wire harness. Autozone.com has wiring diagrams online for free to trace the temp
gauge wires. An aftermarket temp gauge wouldn't be a bad idea for better accuracy
and a trans temp gauge would be nice also since you are in Florida too and towing in
the summer can really heat them up a gauge will let you know when to down shift
or pull over or give you a idea if your cooler is too small!! The window motor is most
likely the 3 plastic things not the gear itself, Use a butter knife to pry the clips off
the door panels be sure to hold tightly to the door panel if it slips the plastic around
the switches can crack!! If it has never been replaced you will need to drill out the
3 DIMPLES not the rivets!!!!!!! If you drill the rivets you are royally screwed since
the spring will uncoil. Be sure to lube everything up with PB corrosion stop or white
lithium when you put it back together to keep it moving smoothly in the future.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #3 (permalink)
Old 06-01-2008, 05:41 PM
Just to update this thread, the truck is a regular daily driver now.
Fixed the driver's side window 2 weeks ago. The bushings were absolutely pulverized.
Friday repaired the cruise at temp guage at the stealership. 510$. Needed a new oil and temp guage, and the switches in the steering wheel had to be replaced. But it's a good strong daily driver, my dad is more than thrilled. Runs like the day it came off the lot.
__________________
2004 Expedition
Eddie Baur 4x2
5.4L 2v Triton V8
NEW: 2 3/4" pipe with Flowmaster Super 50 Delta Flow Muffler and 3.5"x18" echo tip WOOT
Upcoming:
Dual 16" Troyer performance fans
WAAG grill guard
Scanguage II
all corners air suspension
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
