what would it take
Old 11-30-2007, 07:31 PM
arkredneck's Avatar
arkredneck
arkredneck is offline
what would it take
what would it take to get 1000 ft. lbs of torque out of these trucks
Old 11-30-2007, 07:32 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
at the wheels or at the flywheel?
Old 11-30-2007, 07:33 PM
ForemanES's Avatar
ForemanES
ForemanES is offline
bigger injector and turbo, but a lot of supporting mods need to be done to keep up with it.
Old 11-30-2007, 07:34 PM
c00nhunterjoe
at the flywheel i would gues, the 400 and some cc hybrid injectors, big fuel system, big oil system, maybe compund turbos or a really big single? then lots of base engine work, such as o-ringed block, main girdles and rocker girdles, head studs
Old 11-30-2007, 07:38 PM
arkredneck's Avatar
arkredneck
let me re ask my question how much could i do to the truck without having to get into head studs or engine internals just bolt ons like injectors turbo superduty hpop oil pump things like that
Old 11-30-2007, 07:44 PM
ForemanES's Avatar
ForemanES
About 500 hp. Head studs are needed when boost is over 40psi.
(click here)
But your right on the line of playing with fire.
Old 11-30-2007, 07:45 PM
arkredneck's Avatar
arkredneck
would that be 500 at the wheels?
Old 11-30-2007, 07:53 PM
glasseater's Avatar
glasseater
glasseater is offline
yes at the wheels... but 500hp at the wheels is ~1000 ft lbs of torque so that answers your question!!!
Old 11-30-2007, 08:43 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
without studs 400hp is playing with fire. the real mark is 40 psi boost but 500hp requires a full engine build, well and do more than dyno runs with it!
Old 11-30-2007, 08:47 PM
glasseater's Avatar
glasseater
wasn't luke in the 460s without studs or a built engine??
Old 11-30-2007, 09:26 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
I don't know. But if you don't have the cash to build a second engine you had better built the first on right or cut back on your HP.
Old 12-01-2007, 09:25 AM
arkredneck's Avatar
arkredneck
well don't have the cash for 2 engines could you put a fail safe on the truck to defuel it when it hits say 35 psi so you don't tear it up
