Help, need part #
Help, need part #
My injector wiring harness burned out and also damaged the plug on the outside(big plug, 5 pin from the main wiring harness) I've got a wiring harness from parts house but not able to get the plug (they cant seem to locate a # on the computer) Is this a dealer item only??
http://www.thedwilsons.com/powerstro...t_Numbers.html
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve Cover Pigtails with plug and wires, OBS
(Performance Specialties) 99288
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Harness "Wedge" repair (not sure of years it fits or what it looks like)
(Ford) 2c3z-14a163-ab
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
Taken from the link at the top, if that's not it there are some good links that can help. You will want to bookmark this page, it rocks!
(Ford) F4TZ-6584-A
