Help, need part # - Ford Truck Enthusiasts Forums
Help, need part #
Old 12-01-2007, 10:23 AM
wormy1433 wormy1433 is offline
wormy1433 is starting off with a positive reputation.
Help, need part #
My injector wiring harness burned out and also damaged the plug on the outside(big plug, 5 pin from the main wiring harness) I've got a wiring harness from parts house but not able to get the plug (they cant seem to locate a # on the computer) Is this a dealer item only??
Old 12-01-2007, 11:00 AM
fuelman fuelman is offline
fuelman is gaining momentum as a positive member of FTE.
Powerstroke Shop-317-808-1500 if your talking about 5 wire pigtail out of main harness,7.60plus shipping .Easier to call than find on web site.I just ordered 3 myself.
Old 12-01-2007, 11:14 AM
bodabdan's Avatar
bodabdan bodabdan is offline
bodabdan has a good reputation on FTE.bodabdan has a good reputation on FTE.
http://www.thedwilsons.com/powerstro...t_Numbers.html
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve Cover Pigtails with plug and wires, OBS
(Performance Specialties) 99288
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Harness "Wedge" repair (not sure of years it fits or what it looks like)
(Ford) 2c3z-14a163-ab
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
Taken from the link at the top, if that's not it there are some good links that can help. You will want to bookmark this page, it rocks!
Old 12-01-2007, 11:41 AM
thanks for the fast reply, I'm on the phone trying to get the plug now.
Old 12-01-2007, 11:51 AM
bodabdan's Avatar
Let us know if that's the right numbers. Good luck
Old 12-01-2007, 12:02 PM
The powerstroke shop are complete pigtail ,connector and 8in wires ready to splice in.I wouldn't use but connectors but rather solder them in or twist together then put 2 layers of heat shrink around them they will be moisture tight and good to go.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
