F150-to-F250 conversion? - Ford Truck Enthusiasts Forums
Old 11-30-2007, 10:14 PM
hucka1a's Avatar
hucka1a hucka1a is offline
hucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to all
Is it possible (practical) to take the front and rear ends, and the springs from a 89 F250, and put them on a 90 F150. The reason I'm asking is I have a 90 2wd F150. A friend of mine just bought a wreaked 89 4wd F250 for the motor. He said I could have the rest of the truck if I could use it. So really I would like to try to build a 4wd 3/4 ton out of a 2wd 1/2 ton. Or would this be more trouble than its worth?
Thanks
Old 11-30-2007, 11:18 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
It's probably way less trouble to put your motor into the 4wd chassis. I doubt very much that the front end of the frames on the 4x4 and 2x4 are the same, so there would be a lot of fab work involved to get the leaf spring mounts hung properly. Also keep in mind that the F250 uses the goofy swing axle front end, and the necessary mounts/brackets etc. for those would be a pain to transfer to the 2wd frame. I'd put your motor and straight panels on the F250 and call it good.
Old 12-01-2007, 01:48 AM
icrman icrman is offline
icrman is starting off with a positive reputation.
I would use the 3/4 ton frame and running gear and put your cab etc on it.
I think the frame is thicker material than on the 1/2 ton one.
Old 12-01-2007, 01:56 AM
bf250's Avatar
bf250 bf250 is offline
bf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to behold
it would be easier to swap things into the wrecked truck.
it is big work, depending on your ability of course, to do a 4wd conversion on something as compared doing a body and engine swap.
Old 12-01-2007, 07:41 AM
Tom92F150's Avatar
Tom92F150 Tom92F150 is offline
Tom92F150 is starting off with a positive reputation.
Fronts of the frames are not the same; the D50 ttb (Twin-Traction-Beam) is not a bolt-on on the F150 frame. Pivot points are different and the F250 uses leaf springs vs. coils on the F150.
I'll fourth the idea of swapping the engine and sheetmetal onto the 3/4 ton frame if possible. If the F250 frame is bent from the wreck, you can convert your F150 to 4wd using the transmission and t-case, but you'll have to find a D44 ttb out of another F150 or Bronco from 80-96. That axle assembly will actually bolt in place of the Twin-I-Beam 2wd front axle you have now.
And if you just want to (like myself) you can swap in the Sterling 10.25 rear axle from the F250 and convert the D44 ttb to 8 lug using chevy hubs and spindles. At least the drivetrain would be 3/4 ton if not the rest of the truck.
Old 12-01-2007, 03:03 PM
Please tell me you didn't just suggest using Chevy parts on a Ford!
Old 12-01-2007, 03:35 PM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
i am with the majority as well. hang the parts off your truck on the wrecked 250 it will be worth it. well unless your 4x2 is a 4.9
Old 12-01-2007, 03:46 PM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
alchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to behold
Quote:
I am really sorry to tell you this. Bad news it is. But, years ago the "Big 3" shared a lot of common parts - transfer cases, transmissions, rear ends, etc. Dodge and chevy 6 bolt wheels were identical.
Sorry to burst your bubble...............
Old 12-01-2007, 06:29 PM
As were Dodge/Chevy/Ford 8 lug wheels. My snow tires for my truck are mounted on wheels that came off my 87 Chevy 3/4 ton 4x4. I was just flingin' some crap giving Tom92F150 a hard time
Old 12-01-2007, 11:09 PM
hucka1a's Avatar
thanks guys,
I'll just scrap this idea the frame on the 250 is bent. I appreciate all the info.
How many 2wd are out there cherrybomb37 1987 - 1996 F150 & Larger F-Series Trucks 73 10-28-2012 11:19 PM
F250 -1991 2wd using a 4wd transmission, 4wd conversion maybe in future sverker 1987 - 1996 F150 & Larger F-Series Trucks 6 11-12-2011 07:03 AM
96 2wd to 4x4 using 89 D50 axle???? nstueve Offroad & 4x4 5 03-24-2011 04:48 PM
78 F 250 super cab 2wd converting to 4wd 78ecf250cs 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-04-2010 10:35 PM
1/4 ton 1/2 ton 3/4 ton blah... Cablesplicer 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-12-2003 10:44 PM
Tags
150, 2wd, 34, 4x4, 96, conversion, convert, f150, f250, ford, fseries, leaf, spring, ton, tonage, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
