Fuel Leak
Old 11-30-2007, 07:37 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
PAVEMENTMAN is offline
Fuel Leak
I FOUND A SMALL PUDDLE OF FUEL LAYING IN THE VALLEY ON MY MOTOR WOULD THIS BE THE FUEL PUMP AND IF SO ARE THEY HARD TO CHANGE. I CHANGED MY FUEL FILTER ABOUT A MONTH AGO AND LEFT 2 GASKETS ON AND MAYBE THOUGHT IT WAS THAT BUT FIXED THAT AND THE PUDDLE IS STILL COMMING BACK NOT BAD THOGH. WILL THIS GET WORSE.
Old 11-30-2007, 08:14 PM
plowhand's Avatar
plowhand
plowhand is offline
Playing in the Dirt
It could be the fuel pump. Check this: https://www.ford-trucks.com/forums/6...-question.html The pump is not too hard to change. Check here: https://www.ford-trucks.com/forums/5...ight=fuel+pump
Let us know if we can help.
Old 11-30-2007, 09:08 PM
RacerLT250R's Avatar
RacerLT250R
RacerLT250R is offline
check the high pressure rubber fuel lines around the fuel filter canister, i had to replace all 4 or 5 of them when i had diesel in the valley.
Old 11-30-2007, 09:22 PM
PAVEMENTMAN
I Cleaned The Area With A Degreaser And Let It Idle For Awhile And No Leaks. I Drove It Up The Road And Back And Now Theres A Small Puddle Under The Fuel Pump Looks Like It Comes From Under The Fuel Filter Housing Or The Front Of The Fuel Pump. It Only Leaks When I Drive It. Not Idling.
Old 12-01-2007, 05:40 AM
1979FordF250's Avatar
1979FordF250
1979FordF250 is offline
Mine did not leak at idle either and it was the fuel pump. Its probably leaking from the weep hole on the pump which means the pump is dying. Fuel canister cracks and leaks are common too. You have to clean it again and try going for a shorter drive, maybe just back and forward in the driveway..
Old 12-01-2007, 10:19 AM
PAVEMENTMAN
Its A Very Small Puddle. Wonder How Long It Will Last. If It Was The Canister You Would Think It Would Always Leak If It Was Cracked.
hhowell1990
23
01-15-2013 04:21 PM
BENG0924
01-07-2009 09:40 AM
adamant0
12-19-2006 08:01 PM
Jrmobb
Bronco II
02-05-2004 08:45 AM
Quick Reply: Fuel Leak
