Fuel Leak - Ford Truck Enthusiasts Forums
Fuel Leak
Old 11-30-2007, 08:37 PM
PAVEMENTMAN PAVEMENTMAN is offline
PAVEMENTMAN is starting off with a positive reputation.
Fuel Leak
I FOUND A SMALL PUDDLE OF FUEL LAYING IN THE VALLEY ON MY MOTOR WOULD THIS BE THE FUEL PUMP AND IF SO ARE THEY HARD TO CHANGE. I CHANGED MY FUEL FILTER ABOUT A MONTH AGO AND LEFT 2 GASKETS ON AND MAYBE THOUGHT IT WAS THAT BUT FIXED THAT AND THE PUDDLE IS STILL COMMING BACK NOT BAD THOGH. WILL THIS GET WORSE.
Old 11-30-2007, 09:14 PM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
It could be the fuel pump. Check this: http://www.ford-trucks.com/forums/67...-question.html The pump is not too hard to change. Check here: http://www.ford-trucks.com/forums/50...ight=fuel+pump
Let us know if we can help.
Old 11-30-2007, 10:08 PM
RacerLT250R RacerLT250R is offline
RacerLT250R is starting off with a positive reputation.
check the high pressure rubber fuel lines around the fuel filter canister, i had to replace all 4 or 5 of them when i had diesel in the valley.
Old 11-30-2007, 10:22 PM
I Cleaned The Area With A Degreaser And Let It Idle For Awhile And No Leaks. I Drove It Up The Road And Back And Now Theres A Small Puddle Under The Fuel Pump Looks Like It Comes From Under The Fuel Filter Housing Or The Front Of The Fuel Pump. It Only Leaks When I Drive It. Not Idling.
Old 12-01-2007, 06:40 AM
1979FordF250 1979FordF250 is offline
1979FordF250 is starting off with a positive reputation.
Mine did not leak at idle either and it was the fuel pump. Its probably leaking from the weep hole on the pump which means the pump is dying. Fuel canister cracks and leaks are common too. You have to clean it again and try going for a shorter drive, maybe just back and forward in the driveway..
Old 12-01-2007, 11:19 AM
Its A Very Small Puddle. Wonder How Long It Will Last. If It Was The Canister You Would Think It Would Always Leak If It Was Cracked.
Fuel leak hhowell1990 1999 - 2003 7.3L Power Stroke Diesel 23 01-15-2013 05:21 PM
Oil Leak In The Valley BENG0924 1999 - 2003 7.3L Power Stroke Diesel 8 01-07-2009 10:40 AM
Fuel In The Valley adamant0 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-19-2006 09:01 PM
Puddle Lamps chazglenn3 Explorer, Sport Trac, Mountaineer & Aviator 0 05-02-2005 08:31 PM
going through puddles? Jrmobb Bronco II 3 02-05-2004 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
