what would it take - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
what would it take
Old 11-30-2007, 08:31 PM
arkredneck's Avatar
arkredneck arkredneck is offline
arkredneck is starting off with a positive reputation.
what would it take
what would it take to get 1000 ft. lbs of torque out of these trucks
Old 11-30-2007, 08:32 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
at the wheels or at the flywheel?
Old 11-30-2007, 08:33 PM
ForemanES's Avatar
ForemanES ForemanES is offline
ForemanES is gaining momentum as a positive member of FTE.ForemanES is gaining momentum as a positive member of FTE.
bigger injector and turbo, but a lot of supporting mods need to be done to keep up with it.
Old 11-30-2007, 08:34 PM
at the flywheel i would gues, the 400 and some cc hybrid injectors, big fuel system, big oil system, maybe compund turbos or a really big single? then lots of base engine work, such as o-ringed block, main girdles and rocker girdles, head studs
Old 11-30-2007, 08:38 PM
arkredneck's Avatar
let me re ask my question how much could i do to the truck without having to get into head studs or engine internals just bolt ons like injectors turbo superduty hpop oil pump things like that
Old 11-30-2007, 08:44 PM
ForemanES's Avatar
About 500 hp. Head studs are needed when boost is over 40psi.
(click here)
But your right on the line of playing with fire.
Old 11-30-2007, 08:45 PM
arkredneck's Avatar
would that be 500 at the wheels?
Old 11-30-2007, 08:53 PM
glasseater glasseater is offline
glasseater is starting off with a positive reputation.
yes at the wheels... but 500hp at the wheels is ~1000 ft lbs of torque so that answers your question!!!
Old 11-30-2007, 09:43 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
without studs 400hp is playing with fire. the real mark is 40 psi boost but 500hp requires a full engine build, well and do more than dyno runs with it!
Old 11-30-2007, 09:47 PM
Quote:
wasn't luke in the 460s without studs or a built engine??
Old 11-30-2007, 10:26 PM
tjbeggs's Avatar
I don't know. But if you don't have the cash to build a second engine you had better built the first on right or cut back on your HP.
Old 12-01-2007, 10:25 AM
arkredneck's Avatar
well don't have the cash for 2 engines could you put a fail safe on the truck to defuel it when it hits say 35 psi so you don't tear it up
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
