D1 vs. D2
If you talkin bout number 1 and number 2 then you used the right one as long as it wasnt red (offroad fuel). No.2 is Diesel fuel and no.1 is Kerosene. You do not want to use Kerosene straight because it hase no lubricity and will damage your engine but a mix is ok more no.2 than no.1 you can run in winter, but is not needed no.2 is recommended for all temps unless it is seriously cold where you live below 10 degrees or so then you could mix to reduce gelling. Kerosene burns hotter and like I said before has no lube so it will hurt the fuel system and engine is used by itself.
------------Jeremy
------------Jeremy
------------Jeremy
------------Jeremy
Look here: http://www.dieselnet.com/standards/us/fuel.html
Up "north" they start selling #1 along with #2 for winter use.
we actually just went over this in school today...its pretty neat...we even talked about what actually comes out of a barrel of crude oil and the percents are shocking. I have a whole book on fuels and lubes...just a little info only 1/2 a gallon from a 42 gallon barrel of crude is useable for lubricating oil (engine oil). If i get a chance ill post a pic of the pie chart.
---------------Jeremy
Frank-1
11-03-2014 03:41 PM
smoky_diesel
11-14-2011 09:50 AM
xjpilot
03-08-2008 06:43 PM
