D1 vs. D2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
D1 vs. D2
Old 11-30-2007, 07:03 PM
tndiesel tndiesel is offline
tndiesel is starting off with a positive reputation.
D1 vs. D2
I filled up today at a different station and noticed that I had filled up with D2 diesel. What the heck did I put in my tank! Sometimes I'm so pre-occupied I don't pay attention like I should.
Old 11-30-2007, 07:19 PM
jboard's Avatar
jboard jboard is offline
jboard is starting off with a positive reputation.
If you talkin bout number 1 and number 2 then you used the right one as long as it wasnt red (offroad fuel). No.2 is Diesel fuel and no.1 is Kerosene. You do not want to use Kerosene straight because it hase no lubricity and will damage your engine but a mix is ok more no.2 than no.1 you can run in winter, but is not needed no.2 is recommended for all temps unless it is seriously cold where you live below 10 degrees or so then you could mix to reduce gelling. Kerosene burns hotter and like I said before has no lube so it will hurt the fuel system and engine is used by itself.
------------Jeremy
Old 11-30-2007, 07:43 PM
Quote:
------------Jeremy
Well, I don't know if it was red but it was just a normal Shell station.
Old 11-30-2007, 07:47 PM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
Look here: http://www.dieselnet.com/standards/us/fuel.html
Up "north" they start selling #1 along with #2 for winter use.
Old 11-30-2007, 08:25 PM
jboard's Avatar
we actually just went over this in school today...its pretty neat...we even talked about what actually comes out of a barrel of crude oil and the percents are shocking. I have a whole book on fuels and lubes...just a little info only 1/2 a gallon from a 42 gallon barrel of crude is useable for lubricating oil (engine oil). If i get a chance ill post a pic of the pie chart.
---------------Jeremy
Old 11-30-2007, 08:48 PM
jboard's Avatar
Here it is:
Old 11-30-2007, 08:53 PM
jboard's Avatar
Further down the list the less refined the product.
------------------Jeremy
Anyone filled in their 48-50 instrument cluster? Frank-1 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 11-03-2014 04:41 PM
Filled up Today Tom 2009 - 2014 F150 8 05-28-2014 03:27 AM
$243.50 Fuel Bill?!! jetpilot2 6.7L Power Stroke Diesel 22 09-20-2012 08:06 AM
Dana 50 oil capacity, 1.8L or up to the fill hole? smoky_diesel 1999 - 2003 7.3L Power Stroke Diesel 2 11-14-2011 10:50 AM
Sticky Fuel tank sending unit? xjpilot 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-08-2008 07:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
