11-30-2007, 04:38 PM
Sounds like it would work fine. I am planning on doing something similar to mine. You could use either rubber or steel lines. Be sure to use some grommets on the holes though.
Shortly after I got mine it kept getting vapor locked - somewhere along the line someone jumbled the lines up, and I had a 'fun' time figuring it all out - tore out all the old and 'who knows when installed', and ran a rubber line along the top of the frame to get it going again, and I plan on running a steel line through the frame.
__________________
04 F250 PSD
73 Bronco
