intake manifold torque specs?
Old 11-15-2001, 04:31 PM
troys68's Avatar
troys68
troys68 is offline
Hi,
I am installing an aluminum Clifford intake on my 300. Can anyone tell me what the torque mounting specs are for an aluminum intake on this motor? I have posted this same question on a few other message boards, but haven't had any replies yet. I'm wondering if anyone really knows? Thanks.
Old 11-15-2001, 06:17 PM
wildjon300ci's Avatar
wildjon300ci
wildjon300ci is offline
I did the same thing. I just went with the stock torque specs in the Haynes Manuals. You'll really love the stuff when you put it on. I really love mine!!
Old 11-15-2001, 09:06 PM
troys68's Avatar
troys68
troys68 is offline
Well, I thought maybe the factory specs might have been a little much considering the aluminum. That's the reason I asked. Thanks Wildjon. I'll let ya know if I spin the rubber off my rims after I'm done, haha. Thanks!
Old 11-15-2001, 11:22 PM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
The stock lower intake on the newer 300's is aluminum & the torque specs are not a lot either , 22 Ft lbs to 32 Ft Lbs & make sure you torque the bolts in the proper sequence as well . Id go with a lower torque setting too , I cracked a lower intake going with the 32 Ft Lb setting , it snapped one of the ears off that the bolts contact . 25 Ft Lbs seems to be plenty in my experience .
Old 11-16-2001, 10:55 PM
cheeseheadmike's Avatar
cheeseheadmike
cheeseheadmike is offline
Old 11-17-2001, 09:46 AM
troys68's Avatar
troys68
troys68 is offline
Thanks for the replies. I got my truck running last night. Today I've got to install my Lokar accelerator pedal and cable and hook my muffler back up. I couldn't believe this was the same motor when I fired it up! You can actually hear the cam now that the motor is able to breathe. The motor has an Isky 262 supercam whtich has a .445 valve lift and 208 deg. duration on a 108 center. I didn't think you would hear the cam very much, but oh man! I'll get a picture uploaded maybe sometime today.
Psyclopse
05-07-2015 01:02 PM
bluesky636
02-11-2004 08:00 PM
fordusa
07-26-2003 09:48 PM
Karm
04-20-2003 02:58 PM
Quick Reply: intake manifold torque specs?
