Modular V10 (6.8l)
99' V10
Old 11-30-2007, 07:35 AM
uh60's Avatar
uh60
uh60 is offline
99' V10
I found a 99' V10 4x4 xlt with 77000 on it for $10900. I am hesitant about it because it is the first year for that body style and the V10. I know the 99' V10 was only 260 hp and 350 ft lbs tq. Does anyone know of any problems in that year model? What about with the 99' V10? Any info would be greatly appreciated.
Old 11-30-2007, 08:00 AM
uh60's Avatar
uh60
uh60 is offline
P.S. I know about the Spark plug thread problem.
Old 11-30-2007, 09:47 AM
01 superduty's Avatar
01 superduty
01 superduty is offline
I had 99 Superduty v-10 and owned it since it was brand new, has 230,000 miles on it and the only problem it has was a coil went bad and put new plugs in it. That is it, best truck I have ever had, now I have 01 with v-10 with 58,000 miles on it and know problems just has a little more power but put 4.30 gears in it and it helps a lot.
Old 11-30-2007, 10:47 AM
V10_Cougar's Avatar
V10_Cougar
V10_Cougar is offline
Mine is at 150,000 miles w/no problems.
Old 11-30-2007, 11:35 AM
bigskymt's Avatar
bigskymt
bigskymt is offline
I bought my early 1999 brand new and it is the best truck I have ever owned. I had a couple of issues early that were covered under warranty, other than that I have just put oil/gas in it.
Old 11-30-2007, 12:09 PM
msbweiland's Avatar
msbweiland
msbweiland is offline
Mine has 180k and still runs good.
Old 11-30-2007, 04:16 PM
vwovw's Avatar
vwovw
vwovw is offline
130k no problems
Old 11-30-2007, 06:39 PM
mptjelgin's Avatar
mptjelgin
mptjelgin is offline
131k on mine and I just finished a 1000 mile round trip pulling my 10K fifth wheel up into the Davis Mountains in West Texas. Best truck I've ever had.
Old 11-30-2007, 09:19 PM
uh60's Avatar
uh60
uh60 is offline
Thanks for the info. Glad to hear that they didn't have any problems. Maybe it isn't to bad of a deal. Is the MPG about the same as a 00' and newer? Any noticable power difference between a 99' and say a 00'?
Old 11-30-2007, 11:10 PM
be250's Avatar
be250
be250 is offline
have 99' with 118000 no, major prob. put in 4.30 s pulls good . bseg barry
Old 12-02-2007, 08:38 PM
ATXZJ's Avatar
ATXZJ
ATXZJ is offline
Early 99' here with 160k and no major problems. No blown plugs and only replaced one coil. They get about the same fuel mileage as later models (sometimes a little better), have the about the same torque, but tend to run out of steam over 4K. A few basic mods and you'll be fine. Gears are a must, I pull a 13K gooseneck in high elevation and run 4.56s, I wish I would have installed 4.88s instead.
The trans is the only thing I would worry about.
HTH -Marcus
Old 12-02-2007, 09:32 PM
BareBones's Avatar
BareBones
BareBones is offline
In 2005 the SuperDuties got heavier and got more power. As a result it seems the earlier models actually get better mpg.
Old 12-03-2007, 12:16 PM
msbweiland's Avatar
msbweiland
10k sounds good if it's clean. Paid 8k for mine, but it was a "Must Sell" style deal. He had to get rid of it and no one around here wanted a V10. Everyone thinks they need a 7.3/6.0. I have enough headaches working on the oil burners every day, I don't need them at home too.
Pull the oil filler off and see if there is any snot. It'll tell you if it's burning water or not.
Old 12-03-2007, 01:43 PM
vee10td's Avatar
vee10td
vee10td is offline
Talking
According to the '99 Super Duty brochure I'm looking at, the '99 V10(in Super Duty) was factory rated at 275 hp@4,250rpm with 410 lb./ft. of torque@2,650rpm.
Old 12-03-2007, 03:06 PM
uh60's Avatar
uh60
uh60 is offline
Glad to hear that so many have gotten so much milege out of them. Maybe not such a bad deal. Thanks.
Quick Reply: 99' V10
