Loss of power & loud exhaust - Ford Truck Enthusiasts Forums
Old 11-29-2007, 09:16 PM
carkrazd carkrazd is offline
carkrazd is starting off with a positive reputation.
Hi All.
My name is Dana. My wife & I are the proud owners of two power stroke trucks.
One 95 F350 crew cab dually and one 97 F350 crew cab 4x4 (single rear wheel).
Sunday night I was leaving the store and the 95 truck suddenly lost power, became very loud (sounds like exhaust) and tripped the engine light. I have gotten on line and ordered an elm 327 scanner with usb to plug into my lap top so we can scan and get the codes (still a day or two out). If any one has any thoughts or input on this, it would be greatly appreciated.
Thanks.
Friends don't let Friends drive Chevys.
Old 11-29-2007, 10:02 PM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
It could be several things, one of the gaskets on the up pipe gave way (look for soot on the firewall and around the up pipes), EBPV was closing (unplug it at the two wire connector under the turbo. Others will be along to give you more ideas and welcome aboard.
Old 11-30-2007, 05:05 AM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
Welcome to FTE. Has there been any change since Sunday night? Has it gotten worse? Having the codes will be a help, but as plowhand said look for the soot.
Old 11-30-2007, 10:37 AM
I have not ran the truck since sunday. I did not want to make things worse
I hope the scan unit comes in today and we can get to the bottem of this .
Has any one used the ELM 327 unit yet ??
Old 11-30-2007, 11:15 AM
I did look for the soot. looking from the front of the truck I can see some soot on the fire wall (left of the turbo) I put my hand on it and rubbed not much came off. maybe not much is there because the truck was only driven less then 1/4 mile home.
What code would you see if the up pipe was the problem.
Years ago a snapon scanner told us this truck had a turbo problem and it ended up being a cam or crank sensor.
After reading many of your posts I sure think I"am in the right place.
Thanks Dana
Old 11-30-2007, 07:20 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
i'm sticking with the origonal idea of the ebp valve stuck
Old 11-30-2007, 07:27 PM
glasseater glasseater is offline
glasseater is starting off with a positive reputation.
but ebpv stuck wouldn't throw a code would it?? i wouldn't think so since they don't throw a code when unplugged.... but why would uppipe gasket shot cause a code?? the code is confusing me...
Old 11-30-2007, 09:53 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
EPBV won't throw a light ,it will set a code,,My wag is UVCH ot valve cover gaskets....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
