You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I was going to do a 302 conversion on my 84 bronco II but it just poped into my head why not try and drop in a 2.3 and build it up a bit. Something that no one I know has tried. I run 31' bfg tires with an explorer spring lift. Now i would be changing my gears to 4.88's to help out. now I know the 2.3 in 1990 with the 8 plug head was rated around 100 hp and 130 torque. My truck at the moment had the 2.8 which stock was rated at 115 and 150 torque. So If I can get the 2.3 to that level or more would be fun, because with my 23 gallon tank I'm guessing I could get 600 miles or more to the tank. Also was wondering if maybe a 2.5 might be a better swap. Of coarse I want it to remain 4x4 and i feel my 13-50 transfer case is up to the power. Now That leaves me with trying to attach the transfer case to the 4 banger tranny.
I have been collecting parts to do this swap, I had a Ranger with a 2.3 and it seemed to have more power than the 2.8 in my Bronco II and it got a lot better mileage.My Bronco II has the C-5 transmission, I found a 2.3 Ranger at the wreckers with a C-5 so I grabbed the bellhousing,blockplate,flexplate and torque converter.That should take care of mating the engine to the transmission.I am using a Duraspark distributor in my Bronco II with a GM HEI module so I will just use a 2.3 Duraspark in the beginning as I was thinking of starting out carbureted and then switching to fuel injection down the road.I am assuming 4 cyl Ranger mounts should work but I haven't checked it out.Radiator will probably be a 4 cyl Ranger one or the Bronco II one using the fox Mustang lower rad hose which connects on the drivers side and I will probably use an electric fan as well.
Sweet, I have the C5 as well in my truck. I would personally like to run fuel injection because of the off road potential. I will check into finding that bell housing because if i find It I could run My c5 of the 2.3. I'm wondering if there is a possibility of throwing a better tranny behind this motor rather than a 3 speed auto? Something like a M50d or something along those lines so that I have a better gear spread.
I have never really reasearched any other transmission, I like the C-5 because it is an offshoot of the C-4 and should be fairly reliable.And it is already in there.If you don't have an engine, maybe look into a turbocharged 2.3 from one of the Thunderbird Turbocoupes, try to get a rusted out one or a total loss.The best ones are the 87-88 ones as they have the 8.8 rear end you can sell as well as numerous other items you can pawn off on ebay.
